Home > Td5 > Check engine light |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 535 |
Try fuel pump relay and its associated connection. Yellow relay under the drivers seat.
18th Mar 2020 5:48pm |
andrewr Member Since: 17 Feb 2020 Location: Dublin Posts: 2 |
Thanks for such a quick response; much appreciated and will investigate.
18th Mar 2020 6:05pm |
You may see evidence of heating of the connectors. The relay holders can be taken appart to tighten up the terminals, there is a split retainer underneath that once removed allows terminals.
There should be 2 yellow relays one for the fuel pump usually the rearmost one, the other is the main relay. you will work out which one by pulling the relay and listen for the pump stopping. |
18th Mar 2020 6:20pm |
