Home > Td5 > Check engine light
andrewr
Ireland 1999 Defender 90 200 Tdi CSW Rioja Red
Check engine light
Hi - not at all mechanically minded but love my Td5 (1999). Recently the Check engine light has come on when I've gone over a traffic calming lump. It's on for about 3 seconds, the transmission power seems to shudder and then light goes off and power picks up. Anyone else had this and/or have suggestions as to what the cause might be? Thanks Very Happy
Post #820115 18th Mar 2020 5:27pm
htb2
Wales
Try fuel pump relay and its associated connection. Yellow relay under the drivers seat.
Post #820117 18th Mar 2020 5:48pm
andrewr
Thanks for such a quick response; much appreciated and will investigate.
Post #820120 18th Mar 2020 6:05pm
htb2
Wales
You may see evidence of heating of the connectors. The relay holders can be taken appart to tighten up the terminals, there is a split retainer underneath that once removed allows terminals.
There should be 2 yellow relays one for the fuel pump usually the rearmost one, the other is the main relay. you will work out which one by pulling the relay and listen for the pump stopping.
Post #820124 18th Mar 2020 6:20pm
