Home > Technical > New VCV relearn process using Icarsoft V2 diagnostic tool?
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
Hi
I am replacing the Fuel injection pump vapour sensor on my sons 2.4 Puma as it has all the classic symptoms as discussed on this site.
After fitting I will apparantly need to carry out -
Using diagnostic system carry out the pump learn procedure.
Using diagnostic system carry out the pilot correction procedure.
Does anyone know if this can be done with the Icarsoft V2 diagnostic tool.
Also if after fitting it has to be calibrated by a garage will the motor run ok good enough to get it a few miles to a garage?
Thanks
Post #804210 30th Nov 2019 5:23pm
Bluest
If all you are doing is the VCV (volume control valve) you don’t need to do the pilot correction, I think that’s to do with the injectors. You can do the fuel pump learn if you want, but the car will do it itself over time anyway.
I replaced my VCV did nothing and it drove perfectly. I did do a pump learn a while later with a Nanocom and it made no difference as far as I could tell 2007 110 TDCi Station Wagon XS
Post #804212 30th Nov 2019 5:30pm
foggydave
Thanks Bluest Thats just what I wanted to hear. I would not be bothered too much about paying for a relearn as long as the motor will get there.
Post #804229 30th Nov 2019 7:24pm
foggydave
I have just read that when changing the VCV it is also advisable to change the Common Rail Sensor.
Would that need a relearn or is it a fit and forget?
Post #804246 30th Nov 2019 9:14pm
I don't know where you read that, but I have replaced several VCVs over the last 245,000 miles and never have I replaced the sensor or the PRV. So my advice would be don't, unless you like giving money to parts suppliers!
Post #804251 30th Nov 2019 9:48pm
jst
last vcv change I did 10k ago I didn't do any software changes/learns.
where is a good place to get a vcv currently, for a 2.4, I have another that needs doing. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #804349 1st Dec 2019 8:08pm
foggydave
JST go to the Land Rover Workshop site. Looking at the diagrams find the part and part number and you will see a list of suppliers and prices. I find the site really useful for getting part numbers and prices
Thanks all for the input. With the diagnostiic tool although no fault codes came up we found a large fluctuation in the fuel line pressure which may be another indication that the valve is at fault.
I THINK the part number is LR009837 My sons motor is a 2.4 2007.
Post #804433 2nd Dec 2019 12:21pm
Bluest
When I bought mine PF Jones in Manchester were cheapest for Denso one. 2007 110 TDCi Station Wagon XS
Post #804448 2nd Dec 2019 2:24pm
spudfan
Ireland
VCV changed and no learning. 2.4 Puma. I think the only learning process is the fact that it is an awkward little yoke to change and you tell yourself that you will get someone else to do it in the future Mr. Green 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #804716 4th Dec 2019 12:17pm
foggydave
Hi
Yes Spudfan. I had a call last night. My lad had got a valve and was trying to figure out how to fit it. The way he was talking he needs to take the manifold off along with some other bits and pieces. He is not a happy chappy. Smile
THanks all for the help its very much appreciated.
Post #804743 4th Dec 2019 4:58pm
Bluest
When I did mine, I think the only thing I removed was the hose form the vacuum pump. And I've got fat fingers. 2007 110 TDCi Station Wagon XS
Post #804749 4th Dec 2019 5:37pm
foggydave
Thanks I will tell him and make him a happy chappy. ....... For a change
Post #804753 4th Dec 2019 6:16pm
jst
I posted a how to thread on here somewhere, 2nd time takes 10mins or so.
Thanks for heads up on suppliers Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #804789 4th Dec 2019 10:24pm
jst
My post 15 nov 18 on how to. Looks like parts suppliers are same as above now as then
https://www.defender2.net/forum/topic25121-120.html Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #804790 4th Dec 2019 10:30pm
spudfan
Ireland
I used a Denso replacement and no learning process. 1982 88" 2.25 diesel
Post #806612 17th Dec 2019 12:54pm
