Home > Technical > New VCV relearn process using Icarsoft V2 diagnostic tool? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4219 |
If all you are doing is the VCV (volume control valve) you don’t need to do the pilot correction, I think that’s to do with the injectors. You can do the fuel pump learn if you want, but the car will do it itself over time anyway.
I replaced my VCV did nothing and it drove perfectly. I did do a pump learn a while later with a Nanocom and it made no difference as far as I could tell 2007 110 TDCi Station Wagon XS |
30th Nov 2019 5:30pm |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
Thanks Bluest Thats just what I wanted to hear. I would not be bothered too much about paying for a relearn as long as the motor will get there.
30th Nov 2019 7:24pm |
I have just read that when changing the VCV it is also advisable to change the Common Rail Sensor.
Would that need a relearn or is it a fit and forget? |
30th Nov 2019 9:14pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17475 |
I don't know where you read that, but I have replaced several VCVs over the last 245,000 miles and never have I replaced the sensor or the PRV. So my advice would be don't, unless you like giving money to parts suppliers!
30th Nov 2019 9:48pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8097 |
last vcv change I did 10k ago I didn't do any software changes/learns.
where is a good place to get a vcv currently, for a 2.4, I have another that needs doing. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
1st Dec 2019 8:08pm |
JST go to the Land Rover Workshop site. Looking at the diagrams find the part and part number and you will see a list of suppliers and prices. I find the site really useful for getting part numbers and prices
Thanks all for the input. With the diagnostiic tool although no fault codes came up we found a large fluctuation in the fuel line pressure which may be another indication that the valve is at fault. I THINK the part number is LR009837 My sons motor is a 2.4 2007. |
2nd Dec 2019 12:21pm |
When I bought mine PF Jones in Manchester were cheapest for Denso one. 2007 110 TDCi Station Wagon XS |
2nd Dec 2019 2:24pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4722 |
VCV changed and no learning. 2.4 Puma. I think the only learning process is the fact that it is an awkward little yoke to change and you tell yourself that you will get someone else to do it in the future 1982 88" 2.25 diesel
4th Dec 2019 12:17pm |
Hi
Yes Spudfan. I had a call last night. My lad had got a valve and was trying to figure out how to fit it. The way he was talking he needs to take the manifold off along with some other bits and pieces. He is not a happy chappy. THanks all for the help its very much appreciated. |
4th Dec 2019 4:58pm |
When I did mine, I think the only thing I removed was the hose form the vacuum pump. And I've got fat fingers. 2007 110 TDCi Station Wagon XS
4th Dec 2019 5:37pm |
Thanks I will tell him and make him a happy chappy. ....... For a change
4th Dec 2019 6:16pm |
I posted a how to thread on here somewhere, 2nd time takes 10mins or so.
Thanks for heads up on suppliers Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Dec 2019 10:24pm |
My post 15 nov 18 on how to. Looks like parts suppliers are same as above now as then
https://www.defender2.net/forum/topic25121-120.html Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Dec 2019 10:30pm |
I used a Denso replacement and no learning process. 1982 88" 2.25 diesel
17th Dec 2019 12:54pm |
