- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > New VCV relearn process using Icarsoft V2 diagnostic tool? |
foggydave
Hi
My lads fitted the valve. He is not sure which make it was but it worked straight off he says its never run better. He did though find access a tad difficult.
It does seem odd though that the fault diagnosis descision was made on the basis that no fault code registered. The only thing the Icarsoft bought up was an erratic fuel pressure on tick over which we looked at after reading your posts.
So once again thank you all for all the input.
17th Dec 2019 3:34pm |
