Home > Td5 > Td5 Trim Levels
Page 2 of 2 <12
bigfatsi
United Kingdom 2003 Defender 110 Td5 CSW Aintree Green
I've got a county with most of the bits it would appear. Says County on V5. Has aircon, boosts, heated seats & screen, remote central locking with internal alarm sensors, high level brake light and CD but cloth seats and no ABS. Later axle in place. Learn something new everyday!
S
Post #797366 9th Oct 2019 8:59am
The presence of a high level brake light is related to whether the vehicle is a commercial or a passenger vehicle rather than the trim spec. Darren
Post #797372 9th Oct 2019 9:44am
4RF RDS
Rye54 wrote:
OK great, would it state XS on the V5 form? Any other obvious indications that it's a genuine XS spec defender?
To be sure I would say it is best to use a decent VIN decoder. When you go to look at a Defender type the VIN into your phone and see what it left the factory with. Thumbs Up
As an example my 2000 110 CSW Td5 had every option available (Webasto, AC ABS TC etc) at that time but steel wheels...
Good luck in your search
https://www.vindecoderz.com/EN/Land%20Rover 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #797567 10th Oct 2019 3:01pm
JWL
Damn that's a good way to check up on the factory spec of a motor Thumbs Up
Post #797660 10th Oct 2019 11:14pm
Rye54
I shall be sure to use that VIN checker when the time comes Thumbs Up
As an aside (and maybe i should start a new thread for this?) apart from year (10 vs 15p) and general condition/mileage, is there anything else worth keeping in mind when going to buy a TD5 or defender in general for that matter?
I have read about checking for rust, has it been used heavily for towing etc, but if you know of anything else I'd be interested to hear it.
Again cheers for all the previous replies.
R
Post #797751 11th Oct 2019 7:06pm
landy andy
If buying a Td5 always pull the red plug off the ecu and check for oil Thumbs Up Thumbs Up
Make sure TC/abs light comes on and then goes off at 6mph.
Use fuel prime to listen to how noisy the fuel pump is
Post #797816 12th Oct 2019 9:11am
Page 2 of 2 <12
