Home > Td5 > Td5 Trim Levels |
The presence of a high level brake light is related to whether the vehicle is a commercial or a passenger vehicle rather than the trim spec. Darren
9th Oct 2019 8:44am |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 932 |
To be sure I would say it is best to use a decent VIN decoder. When you go to look at a Defender type the VIN into your phone and see what it left the factory with. As an example my 2000 110 CSW Td5 had every option available (Webasto, AC ABS TC etc) at that time but steel wheels... Good luck in your search https://www.vindecoderz.com/EN/Land%20Rover 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
10th Oct 2019 2:01pm |
Damn that's a good way to check up on the factory spec of a motor
10th Oct 2019 10:14pm |
Rye54 Member Since: 09 Jul 2017 Location: Scotland Posts: 48 |
I shall be sure to use that VIN checker when the time comes
As an aside (and maybe i should start a new thread for this?) apart from year (10 vs 15p) and general condition/mileage, is there anything else worth keeping in mind when going to buy a TD5 or defender in general for that matter? I have read about checking for rust, has it been used heavily for towing etc, but if you know of anything else I'd be interested to hear it. Again cheers for all the previous replies. R |
11th Oct 2019 6:06pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5697 |
If buying a Td5 always pull the red plug off the ecu and check for oil
Make sure TC/abs light comes on and then goes off at 6mph. Use fuel prime to listen to how noisy the fuel pump is |
12th Oct 2019 8:11am |
