Home > Technical > Broken down in Belgium |
DunningBoy Member Since: 23 Jul 2016 Location: Middle Posts: 31 |
While waiting for the breakdown truck to arrive I thought I'd see if any gurus on this forum could provide some practical suggestions.
2002 TD5 110 Station Wagon, recently serviced, started ok drove for about 150m the cut out. It won't restart and, after I left it for a while, when turning the ignition key the glow plug light does not illuminate. My first thought was something in the fuel system but could it be electrical? All thoughts gratefully received. |
15th Aug 2019 1:05pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5720 |
Can you hear the fuel pump running in off side wheel arch?
You won’t get glow plug light as too warm. |
15th Aug 2019 1:11pm |
Hi Landy Andy,
Thanks for the suggestion. I can't hear the pump, no. Even after pressing the accelerator pedal a few time to prime the system. I didn't think of that so thanks again. |
15th Aug 2019 1:18pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
Does the engine management light come on?
I had a similar problem and had to keep reseating the Main and Fuel pump relays as they had a bad contact. Just for good measure I also reseated both plugs in the ECU just so everything had a chance. Good luck. |
15th Aug 2019 1:47pm |
Thanks folks. It is now on its way to Namur where they will not look at it till Monday (public holiday in Belgium). All of the fuses and relays seemed ok when the chap tested it with a multimeter. No engine management lights.
Thank heavens for European breakdown cover |
15th Aug 2019 2:22pm |
Phil VM2.5 Member Since: 28 Mar 2012 Location: Limelette Posts: 196 |
Hi,
Its what I do not like, have a breakdown ! And more not at home . I hope you will have some good activities before monday and that will be a good mechanic to find what is wrong. Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and again my Range Rover VM2.5 engine from 1992 and 528.000km today. One ten 1988 to 1992 1987 BMW GS80 One Ten from 1984 to 1987 One Ten from 1983 to 1984 Serie 3 109 from 1980 to 1983 from 1974 Jeep CJ3B and CJ6 |
16th Aug 2019 1:30am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6093 |
Did the water temp gugage go right up? it's not the roll over cut out switch under the bonnet?
16th Aug 2019 6:04am |
CharlieDonuts Member Since: 16 Jun 2019 Location: Illiers Combray Posts: 133 |
My last breakdown like that. They winched it on the the recovery truck then let it roll backwards off the recovery truck whilst jump starting the engine. It started ! I drove it to the local mechanic who replaced the starter motor. It had done 90k.
16th Aug 2019 6:33am |
Thanks for all of the kind responses and suggestions. We've now got a hire car and are on our way home with the Landy still in Namur. We need to get the ferry to Newcastle tomorrow so no chance of getting my truck back in time
The plan is for my insurance to repatriate it but I'm not holding my breath. I had to organise my hire car myself after they told me there was nothing available. There was an Avis depot in the next town who were more than happy to rent me a car. |
16th Aug 2019 7:46pm |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
Sounds like the fuel pump has failed :X
Good luck getting her back quickly. |
16th Aug 2019 8:01pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Hope all gets sorted for you 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
16th Aug 2019 8:05pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2161 |
Not sure how use use it would be but i am pretty near Newcastle if there is something to assist??
16th Aug 2019 8:52pm |
Thanks 90 Dreamer. There should be a hire car waiting for us at the ferry port so that we can at least get back to Scotland.
17th Aug 2019 6:11am |
good news at least........
17th Aug 2019 9:07am |
