Home > Technical > Broken down in Belgium
DunningBoy
While waiting for the breakdown truck to arrive I thought I'd see if any gurus on this forum could provide some practical suggestions.
2002 TD5 110 Station Wagon, recently serviced, started ok drove for about 150m the cut out. It won't restart and, after I left it for a while, when turning the ignition key the glow plug light does not illuminate. My first thought was something in the fuel system but could it be electrical?
All thoughts gratefully received.
Post #786974 15th Aug 2019 2:05pm
landy andy
Can you hear the fuel pump running in off side wheel arch?
You won’t get glow plug light as too warm.
Post #786975 15th Aug 2019 2:11pm
DunningBoy
Hi Landy Andy,
Thanks for the suggestion. I can't hear the pump, no. Even after pressing the accelerator pedal a few time to prime the system. I didn't think of that so thanks again.
Post #786977 15th Aug 2019 2:18pm
dorsetsmith
main relay working ?
fuel pump relay working ?
Is fuse 4 ok Question 20 amp
check earth start at battery
Post #786978 15th Aug 2019 2:40pm
Paddie42
England 2003 Defender 110 Td5 SW Belize Green
Does the engine management light come on?
I had a similar problem and had to keep reseating the Main and Fuel pump relays as they had a bad contact.
Just for good measure I also reseated both plugs in the ECU just so everything had a chance.
Good luck.
Post #786979 15th Aug 2019 2:47pm
DunningBoy
Thanks folks. It is now on its way to Namur where they will not look at it till Monday (public holiday in Belgium). All of the fuses and relays seemed ok when the chap tested it with a multimeter. No engine management lights.
Thank heavens for European breakdown cover Smile
Post #786984 15th Aug 2019 3:22pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
Its what I do not like, have a breakdown !
And more not at home .
I hope you will have some good activities before monday and that will be a good mechanic to find what is wrong.
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #787122 16th Aug 2019 2:30am
Did the water temp gugage go right up? it's not the roll over cut out switch under the bonnet?
Post #787127 16th Aug 2019 7:04am
CharlieDonuts
France 2008 Defender 90 Puma 2.4 SW Galway Green
My last breakdown like that. They winched it on the the recovery truck then let it roll backwards off the recovery truck whilst jump starting the engine. It started ! I drove it to the local mechanic who replaced the starter motor. It had done 90k.
Post #787131 16th Aug 2019 7:33am
DunningBoy
Thanks for all of the kind responses and suggestions. We've now got a hire car and are on our way home with the Landy still in Namur. We need to get the ferry to Newcastle tomorrow so no chance of getting my truck back in time Sad
The plan is for my insurance to repatriate it but I'm not holding my breath. I had to organise my hire car myself after they told me there was nothing available. There was an Avis depot in the next town who were more than happy to rent me a car.
Post #787249 16th Aug 2019 8:46pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Sounds like the fuel pump has failed :X
Good luck getting her back quickly.
Post #787253 16th Aug 2019 9:01pm
Sulisuli
Hope all gets sorted for you 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #787255 16th Aug 2019 9:05pm
90 Dreamer
Not sure how use use it would be but i am pretty near Newcastle if there is something to assist??
Post #787275 16th Aug 2019 9:52pm
DunningBoy
Thanks 90 Dreamer. There should be a hire car waiting for us at the ferry port so that we can at least get back to Scotland.
Post #787298 17th Aug 2019 7:11am
90 Dreamer
good news at least........
Post #787321 17th Aug 2019 10:07am
