Home > Maintenance & Modifications > Shocks and springs what ones?
Page 2 of 2 <12
ibexman
I’ll have the beer Jim 😊
Post #777922 17th Jun 2019 8:27pm
My favourite! Mr. Green Thumbs Up
Post #777940 17th Jun 2019 9:54pm
bear100
Burrows cider from Somerset is my all time favourite.....i'll drink a gallon of it walking around the great dorset steam fair Shocked Very Happy
Well i can't find anything bad with Koni so far apart from the price £114 each
Im leaning more towards the standard springs with air helpers so far, ive had a quick google and am i right in saying an air compressor is used to adjust the height? 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #777964 18th Jun 2019 8:20am
8619simon
Wales 1995 Defender 110 300 Tdi CSW Epsom Green
You can but a bike pump will also do the trick Very Happy
Post #778014 18th Jun 2019 4:33pm
jst
Air helpers have std tyre valves and typically run 5 to 25psi. I run 20 in mine when overlanding packed, 25 when towing, 5 rest of time. As above just adjust with bike pump. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #778081 18th Jun 2019 9:28pm
jocklandjohn
Scotland 1989 Defender 110 200 Tdi HT Oslo Blue
I've got a laden 110 and use standard Land Rover springs front and rear, AirLift bags at back, Armstrong shock absorbers all round, and often carry a lot of stuff, water, extra fuel, fridge, bikes, gear, dog etc and the set up is flexible and works just fine. Pump the bags up with a bike pump, check pressure with tyre pressure gauge.
Post #779418 28th Jun 2019 6:00pm
bear100
Thanks for the info, it looks like this will be my preferred choice!
It seems to tick all the boxes.
Thumbs Up 2016 Range Rover Autobiography 4.4 TDV8
Post #779424 28th Jun 2019 6:47pm
jocklandjohn
There is a 'design flaw' with the AirLift bags - the top of the bag is retained by a plastic plug with a hole to allow the air pipe to exit. Unfortunately under load the plug gradually pops out the top, oddly enough not on all vehicles for some reason.
Anyway mines did, so I contacted the vendor and the told me Airlift were apparently working on a fix.I got fed up waiting so I got creative and solved it myself.
You need a pair of inner spring retainer plates (see diagram) Item 22
and then trim the top plugs to accommodate them. Refit and away you go. Mine have been in for several years and used all over the place, laden, unladen, inroad and off and no problems.
So, buy with confidence but if you DO have the problem there's an easy fix.
You can see the problem above - the plug coming out the top.
Post #779451 28th Jun 2019 8:36pm
Page 2 of 2 <12
