![]() | Home > Maintenance & Modifications > Shocks and springs what ones? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2956 ![]() ![]() |
I’ll have the beer Jim 😊
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6126 ![]() ![]() ![]() |
![]() My favourite! ![]() ![]() |
8619simon Member Since: 04 Nov 2016 Location: North Wales Posts: 254 ![]() ![]() ![]() |
You can but a bike pump will also do the trick
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
Air helpers have std tyre valves and typically run 5 to 25psi. I run 20 in mine when overlanding packed, 25 when towing, 5 rest of time. As above just adjust with bike pump. Cheers
jocklandjohn Member Since: 16 Sep 2016 Location: Highlands Posts: 62 ![]() ![]() ![]() |
I've got a laden 110 and use standard Land Rover springs front and rear, AirLift bags at back, Armstrong shock absorbers all round, and often carry a lot of stuff, water, extra fuel, fridge, bikes, gear, dog etc and the set up is flexible and works just fine. Pump the bags up with a bike pump, check pressure with tyre pressure gauge. |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1953 ![]() ![]() ![]() |
Thanks for the info, it looks like this will be my preferred choice!
It seems to tick all the boxes. ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
There is a 'design flaw' with the AirLift bags - the top of the bag is retained by a plastic plug with a hole to allow the air pipe to exit. Unfortunately under load the plug gradually pops out the top, oddly enough not on all vehicles for some reason.
Anyway mines did, so I contacted the vendor and the told me Airlift were apparently working on a fix.I got fed up waiting so I got creative and solved it myself. You need a pair of inner spring retainer plates (see diagram) Item 22 ![]() and then trim the top plugs to accommodate them. Refit and away you go. Mine have been in for several years and used all over the place, laden, unladen, inroad and off and no problems. So, buy with confidence but if you DO have the problem there's an easy fix. ![]() Click image to enlarge You can see the problem above - the plug coming out the top. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
