Home > My Defender > The Latest - 2011 110 CSW XS
Page 4 of 7 <1234567>
thebigblue
Denmark
GREENI wrote:
TJ101 wrote:
That's a sweet looking 110 Thumbs Up
+1
Can you give me some details on the privacy glass you have on, pls Question
Also like the paint job on the alloys, are they same color as the car Confused:
Post #93396 9th Oct 2011 1:26pm
TJ101
Also like the paint job on the alloys, are they same color as the car Question
Hi,, The privacy was done by a local firm,, have used them many times,, cost ? no idea, as was paid for by the supplying dealer Whistle
The alloys are a very similar shade of grey,, had them a while, and just coincidental they are grey,, just a spare set for offroad work etc
A bit more info on Defender 110 XS No4 topic http://www.defender2.net/forum/topic5576.html[/url] California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #93417 9th Oct 2011 3:25pm
wildrover
Love the last post picture in comparison to POST no 1.
Tints really improve the look - going to do the same this week.
John - you must do the tints.
Post #93611 10th Oct 2011 7:59pm
JSG
Have tints on the 90 - not keen on the view out for reversing at night. John
2011 Tdci 110 CSW XS
Post #93629 10th Oct 2011 9:14pm
wildrover
Whoops - should have checked the Signature too many LR's I reckon. Smile
Post #93638 10th Oct 2011 9:24pm
JSG
After an abortive attempt at fitting a Raptor cubby box which turned out to be too big for a Puma I took the plunge and ordered a Nakatanenga under cubby safe following a look at bpman's at the L2B.
After taking the original cubby box out I confirmed what others had said - you can use the two existing rear rivnuts in the seat box cover but not the front pair.
It comes with a pair of rivnuts which aren't the same size as the originals and are too large for the holes in the safe which seemed a bit daft. I drilled out the holes in the floor of the safe for the supplied bolts and rivnuts and drilled two new holes in theseat box cover.
Next problem was the lack of a rivnut tool - Following a look on the internet U found info on a 'home made tool' which worked rather well Thumbs Up
Diag of tool from the web.
In use.
Fixed rivnut. John
Post #94136 13th Oct 2011 11:17pm
JSG
Trimmed the carpet around the new rivnuts and put some bolts in the redundant rivnuts at the front.
I fed the 12v feed and earth for the sockets under the carpet and through one of the original holes.
Wired up and bolted in place. John
Post #94137 13th Oct 2011 11:22pm
JSG
When I test fitted at the start I decided it was better with the wooden spacers removed from the bottom of the cubby box. The only problem with this was the thickness (or rather wafer thin-ness) of the recessed holes that the bolts pass through in the floor of the cubby so I decided to add an extra bolt which meant an extra hole through the base of the cubby and the lid of the safe.
Extra hole in lid.
And the extra bolt through the base of the cubby box under the cup holder.
Job done Thumbs Up John
Post #94138 13th Oct 2011 11:27pm
nice work John ..
Post #94152 14th Oct 2011 6:53am
Happyoldgit
Tidy Thumbs Up Steve.
http://forums.lr4x4.com
Post #94219 14th Oct 2011 12:34pm
DefenderOfTheEarth
Stunning 110 there JSG. Mr. Green Defender 110XS SW gone... now VW California 180 4 Motion.
Post #94254 14th Oct 2011 4:31pm
JSG
It spent two days back at Lancasters this week - picked it up this evening.
It had three issues;
The 'handbrake' rattle was still there on occasion - better since they stripped and adjusted it last time but still happening now and again. It has now had a new drum and shoes so we'll see how that goes.
The bolster on the drivers seat back had collapsed so you were resting on the metal frame (I know I'm big but it hasn't happened on any others). New seat back supplied and fitted.
Rear off side passenger door motor was sticking a bit and not always unlocking. New motor and latch fitted.
All under warranty, no hassle and washed before collection Thumbs Up
Still very pleased with the service. John
Post #96656 27th Oct 2011 8:40pm
Def-00
United Arab Emirates 2012 Defender 110 Puma 2.2 SW Fuji White
Can't remember but someone else had the same issue, I did as well. Haha you are lucky to have the whole seat back replaced when I took it in they had to send photos of the damage to LR UK and wait a week to confirm warranty repairs which consisted of only replacing the foam inside the seat back. It was due to me resting my elbow on the cubby box and leaning to one side of the seat I think raising the box would fix this as it's starting to happen again Big Cry . Or cough up and buy better quality seats and replace them. 2012 Fuji White 110 Flattened
Post #96672 27th Oct 2011 9:42pm
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Hi JSG ... My security box should arrive next Friday! Smile From where did you get the "juice" for those 12V sockets? Lighter, radio or straight from the battery ? Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #97587 1st Nov 2011 7:34pm
JSG
Hi, I have fitted an aux fuse box next to the battery and run a feed direct from the battery to that. The feed to the sockets is then via a fuse from the new box under the capet to the sockets. John
Post #97606 1st Nov 2011 9:09pm
