Home > My Defender > The Latest - 2011 110 CSW XS |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
This is the first I've had the step on (apart from the TR) mainly because it saves me bending the rear step when the kids have left it down.
I've seen sliders bolted to the NAS step which I may try if it becomes an issue. Failing that I have an adjustable tow bar in the garage from the 07 John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
16th Jun 2011 8:36am |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 |
Changed the wheels?
16th Jun 2011 2:40pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 |
That's a sweet looking 110 :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
16th Jun 2011 2:41pm |
Swapped out the wiper relay today for the VW '99' to give me a variable speed intermittent wipe and found, then fitted the Defender2 forum sticker that Martin sent me. John
16th Jun 2011 3:09pm |
I think that is an earlier truck - he has so many John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
16th Jun 2011 3:10pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
But not that many,, at the same time defender75,, Same 110, but for trips etc, run a set of 265 BFG's on some spare boosts alloys Sorry John,, back to your topic now PS,, must also get round to doing the interval relay California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
16th Jun 2011 5:10pm |
Whoops, posted in the wrong thread Steve.
16th Jun 2011 7:01pm |
New LR towball removed and new Dixon Bate fitted
Click image to enlarge John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
19th Jun 2011 11:30pm |
MzSunshine Member Since: 29 Mar 2011 Location: Down sarf... Posts: 10 |
Need some chequerplate on that step my man!
20th Jun 2011 12:25am |
Nah - better as it is - you can focus on the shiny ball instead John
20th Jun 2011 12:35am |
Time for some updates.
It has now just done 4,000 miles and is still great to drive. No major problems however the 'handbrake rattle' is still there, Lancasters adjusted it once then I left it with them to have another look at it whilst they refitted the wingtops (fittings weren't flush the first time) and they stripped and cleaned it all. This seemed to fix the problem for a week or two but it has come back again. I'm fairly certain it is the handbrake as it seems hot to the touch after driving which I wouldn't expect normally. Other news is the fitting of a Nakatanenga glove box and the 'almost' fitting of a Raptor cubby box which would have fouled the transfer knob and stuck out over the second row footwell too much. Id like to fit an under cubby safe instead from Brendan but need to find the cash first ...... John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
23rd Sep 2011 11:47pm |
johnnyboy Member Since: 04 Oct 2011 Location: newcastle Posts: 20 |
Hi JSG,
Have you had the handbrake rattle fixed yet, just appeared on mine yesterday ( car was only 2 hours old and 5 miles on the clock). |
8th Oct 2011 5:07am |
No - it seems to be a lot better but still does it sometimes - the handbrake needs adjusting but I suspect that will make it worse.
I will book it in as it also has a sticky rear off side door lock motor. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
8th Oct 2011 9:07am |
Have decided that I will fit a X ENG disc handbrake and be done with it, cannot be hassled back and forward to the garage for £250. Will let you guys know what happens.
8th Oct 2011 5:18pm |
