![]() | Home > My Defender > The Latest - 2011 110 CSW XS |
This is the first I've had the step on (apart from the TR) mainly because it saves me bending the rear step when the kids have left it down.
I've seen sliders bolted to the NAS step which I may try if it becomes an issue. Failing that I have an adjustable tow bar in the garage from the 07 ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
defender75 Member Since: 06 Nov 2010 Location: Germany Posts: 219 ![]() ![]() |
Changed the wheels?
That's a sweet looking 110 :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Swapped out the wiper relay today for the VW '99' to give me a variable speed intermittent wipe and found, then fitted the Defender2 forum sticker that Martin sent me.
I think that is an earlier truck - he has so many ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
![]() ![]() defender75,, Same 110, but for trips etc, run a set of 265 BFG's on some spare boosts alloys Sorry John,, back to your topic now ![]() ![]() Main Brian James Trailer Dealer for South West UK |
Whoops, posted in the wrong thread
![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
New LR towball removed and new Dixon Bate fitted
![]() ![]() Click image to enlarge John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
MzSunshine Member Since: 29 Mar 2011 Location: Down sarf... Posts: 10 ![]() ![]() ![]() |
Need some chequerplate on that step my man!
Nah - better as it is - you can focus on the shiny ball instead
Time for some updates.
It has now just done 4,000 miles and is still great to drive. No major problems however the 'handbrake rattle' is still there, Lancasters adjusted it once then I left it with them to have another look at it whilst they refitted the wingtops (fittings weren't flush the first time) and they stripped and cleaned it all. This seemed to fix the problem for a week or two but it has come back again. I'm fairly certain it is the handbrake as it seems hot to the touch after driving which I wouldn't expect normally. Other news is the fitting of a Nakatanenga glove box and the 'almost' fitting of a Raptor cubby box which would have fouled the transfer knob and stuck out over the second row footwell too much. Id like to fit an under cubby safe instead from Brendan but need to find the cash first ...... John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
johnnyboy Member Since: 04 Oct 2011 Location: newcastle Posts: 20 ![]() ![]() |
Hi JSG,
Have you had the handbrake rattle fixed yet, just appeared on mine yesterday ( car was only 2 hours old and 5 miles on the clock). |
No - it seems to be a lot better but still does it sometimes - the handbrake needs adjusting but I suspect that will make it worse.
I will book it in as it also has a sticky rear off side door lock motor. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Have decided that I will fit a X ENG disc handbrake and be done with it, cannot be hassled back and forward to the garage for £250. Will let you guys know what happens.
