![]() | Home > Puma (Tdci) > Air box modification - Do it!! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17600 ![]() ![]() ![]() |
That's me!
Part numbers I noted for the NuggetStuff filter when I was looking for sensibly-priced alternatives:
Googling any of these numbers will find further alternatives, it is a widely used filter. |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2135 ![]() ![]() |
Blackwolf “its a widely used filter” , your not kidding
![]() Interesting to note is the height of the filter for different manufacturers ranges from 175-178mm and the hole in the bottom, that if I recall correctly, sits on the conical rubber mount in the airbox, ranges from circa 8-10mm, I expect both measurements combine to insure a tight fit 1A FIRST AUTOMOTIVE A60579 ALCO FILTER MD652 AMC Filter IA-385 ASHIKA 20-01-110 BOSCH 1 457 433 275 BREMSI FA2230 CHAMPION W708/606 CLEAN FILTERS MA620 Comline CNS12008, CNS12226 CONTINENTAL 28.0002-0278.2 Coopersfiaam FLI6819 DENCKERMANN A140202 DIAMAX DA2222 DJ PARTS FA1545 Dr!ve+ DP1110.10.0277 DYNAMATRIX DAF830 FIL FILTER HP 4554 A Filtron AM436/1 FLEETGUARD AF1822 Fram CA5369 GCG TURBOS AUSTRALIA RY-A1203 GOODWILL AG 477 HERTH+BUSS JAKOPARTS J1321017 HOFFER 16330, 16449 IAP QUALITY PARTS 121-13042 JAPANPARTS FA-110S JAPKO 20110 JC PREMIUM B21017PR JPN 20F1013-JPN JS ASAKASHI A226J KAGER 12-0220 KAISHIN A226 KAVO PARTS IA--385, IA-385 KLAXCAR FRANCE FA260z KNECHT LX 830 LUCAS FILTERS LFAF359 LYNXauto LA-269 MAGNETI MARELLI 152071758561, eBay Item No. 154084455530 MAHLE LX 830 MANDO MMF015095 MANN-FILTER C 13 103/1 MAPCO 60542 MASTER-SPORT GERMANY 13103/1-LF-PCS-MS MASUMA MFA-349 MAXGEAR 26-1591 Mchanix NSARF-004 MDR MAF-3110 MEAT & DORIA 16330, 16449 MECAFILTER EL3808 MFILTER A 143 MISFAT RM973 MOTAQUIP VFA669 MULLER FILTER PA579 NIPPARTS J1321017 NPS N132N10, N132N17 OPEN PARTS EAF3408.20 OSSCA 06085 PATRON PF1484 PEMEBLA JAPFA-110S PURFLUX A330 PZL Filters WA30300A QH Talbros WA6112 QUINTON HAZELL QFA0485 RED-LINE 36NI017 RIDEX 8A0378 RYCO A1203 SAKURA Automotive A-1882 Sakura Filters AU FA-1882 SCT - MANNOL SB014 SOFIMA S 7169 A Stark SKAF-0060384 STELLOX 71-02011-SX TECNECO FILTERS AR579-I UFI 27.169.00 UNIFLUX FILTERS XA1842 WE PARTS 16330 WILMINK GROUP WG1216839 Wix Filters WA6112 |
I can see now that I had hardly skimmed the surface! Thank you for a useful and possibly definitive list.
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 ![]() |
I was wondering what's the alternatives to a standard airbox for a puma ?nugget .diy bodge and what else ? Am i being a little simplistic? all you need is a as wide a bore tube from wing inlet preferably sealed ( air sensor)to some sort of air reservoir with a filter in it that fits in the space allocated by original airbox..then a pipe to the turbo/engine....I know its probably more complicated for a aftermarket company to introduce a product to the market but the landrover community is innovation and i think nugget needs a little competition.
I might have a we search for inspiration starting at... https://www.carbuilder.com/uk/search?q=air+duct |
I started at topic looking at the options I was aware of. In the end I went with a Nak wintop air intake and a nugget stuff Leo deluxe airbox https://www.defender2.net/forum/topic82616.html |
That would have cost you around 700-800 notes? I personally think its overpriced for what you get ..but that's the joys of defender ownership
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Watching this with interest. I’ve also been on the lookout for a sensibly priced well made option to have a bigger bore hose into the side vent and keep the modified standard air box.
I know some clever people have made something that works but I’m not 100% sure I ever would. |
steveww Member Since: 05 Jan 2022 Location: Malton Posts: 577 ![]() ![]() ![]() |
Success
It's a pain of a job to do and I don't have much skin left on my knuckles. ![]() Click image to enlarge I'm not convinced this little device does much for water separation. I was out in thick fog/drizzle yesterday and when I took the lid off the air box it was damp inside with some small puddles in the webs. Ultimately I think I'll fit the Nugget Stuff wing to air box kit, however, there's a few things on the list in front of it. I'll report back on any difference or not. |
Thug Member Since: 02 Aug 2022 Location: Johannesburg Posts: 20 ![]() ![]() ![]() |
Just bit the bullet and ordered the full Nugget Stuff Airbox kit from Wayne, which once installed I'll match to my Mantec RAI.
dannyragsdale Member Since: 06 Oct 2022 Location: Eastern Highlands, PNG Posts: 40 ![]() ![]() ![]() |
Just did this and took me less than 30 minutes. Helps a lot when you have a reciprocating saw. The little fan came out in pieces, but it came out. I can't tell a difference at this point but I'm trusting that it did make a difference since everyone else says it does
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
Me too, it should arrive today/tomorrow, and then will get my indie to fit it. Will report back afterwards -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
2 orders from SA in the same week.
Makes you think that we hang around in the same circles. ![]() |
First long drive, to Norfolk and back, over the weekend since removing the little fan thingy. No scientific measurement but I think the pick up from low RPM is much better and overall the throttle response feels smoother.
Well worth the time and skinned knuckles. |
