![]() | Home > My Defender > BeaTie |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10896 ![]() ![]() |
It doesn't seem that long ago you got Beatie, time does fly
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5244 ![]() ![]() |
Yeah the laugh is, i have spent less on this one than the 300 TDi
![]() ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
All good then so far
Got some ideas to roll out again, when money picks back up, i will be going on 3 shifts, as flexi furlough bites the dust from next week. So i can start rolling out again
Good news for you then Procta
not so much a rolling upgrade, more like maintenance. My wipers were starting not to wipe the screen properly, i did manage to buy a set of replacement units, of what i had before. Looks like those are now discounted, could i hell get hold of a set of the 306, so i bought another set for the parts stash.
Also my landy seems to have developed a touch of french electrics on the rear indicators. A bit of a fiddle on the rear bulbs and all is working again, so they must have moved. But the mot tester changed all 4 for the test to be sure, for the very 1st mot, when i bought her. Also i have rolled out a bit of an experiment, due to the water in the foot wells again smelling out the cab. So we will see how this goes. ![]() ![]() also gave my steering wheel a tighten too, as it was starting to get a bit of play in the boss, so a few seconds with the allen Key fixed that ![]() This wheel is a bit of a nightmare quality wise, i have had to glue down the fake leather part, with in a matter of months of owning the wheel. I may look at another wheel next year, but this one looks quite OEM for me, and its smaller making driving nicer too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Good bit of maintenance there on Beatie
![]() It would pay to leave the carpet out until you have found the leak, no more damp smell ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Well today was a good day for beatie, Two upgrades to Beatie have happened!
One little treat for you lads, I bought this kit just before new year, and sort of did a rolling out installing it, as i had to replace a few parts of the dash, with the weather been spot on, my dad helped me do the final bits, ![]() He has been red hot on wanting to see the finished job, ![]() ![]() from that ![]() Click image to enlarge to this ![]() Click image to enlarge Also with the weather been great, my mum helped me fit these, which my sister got me for Xmas. ![]() ![]() Click image to enlarge ![]() Click image to enlarge And Beatie is a member of the club now! ![]() Click image to enlarge ![]() Click image to enlarge yeah the window seal has seen better days and so has the window screen, another job that i will have to do at some point. So tomorrow got to do some diag work on the spots, they are not powering on, so i am suspecting the fault is at the switch end or something. ![]() Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
sorted the spot lamp problem, i had the wire in the wrong pin, and one of the wires were not contacting the switch. A little bit of a shove with a very small screw driver and that was sorted.
They look great, my dad thinks they are better than his!, which i don't think so as his has a 3 way system dipped and full beam. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Nice additions there Procta and good you got the spots sorted out
gave her a nice oil change and filters, found out that the back box is blown, in the same place my TDI was
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 ![]() ![]() |
![]() Very nice... I keep contemplating some fog type lights ready for the fog we get here on the cold mornings.. Have you got a heated windscreen? worth upgrading if you are going to change anyway... ![]() |
Long time no see!!
yeah this one does have a heated window screen, has a chip in it sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
Looks like Beatie has an Major oil leak,
