Home > My Defender > BeaTie |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10830 |
It doesn't seem that long ago you got Beatie, time does fly Clayton.
6th Apr 2021 8:50pm |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5213 |
Yeah the laugh is, i have spent less on this one than the 300 TDi And that's on fuel for a start Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
8th Apr 2021 12:49am |
All good then so far Clayton.
8th Apr 2021 8:44pm |
Got some ideas to roll out again, when money picks back up, i will be going on 3 shifts, as flexi furlough bites the dust from next week. So i can start rolling out again Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
28th May 2021 11:21pm |
Good news for you then Procta Clayton.
1st Jun 2021 7:46pm |
not so much a rolling upgrade, more like maintenance. My wipers were starting not to wipe the screen properly, i did manage to buy a set of replacement units, of what i had before. Looks like those are now discounted, could i hell get hold of a set of the 306, so i bought another set for the parts stash.
Also my landy seems to have developed a touch of french electrics on the rear indicators. A bit of a fiddle on the rear bulbs and all is working again, so they must have moved. But the mot tester changed all 4 for the test to be sure, for the very 1st mot, when i bought her. Also i have rolled out a bit of an experiment, due to the water in the foot wells again smelling out the cab. So we will see how this goes. Looks like i will have to replace the two piece of carpet i the floor pans sadly. also gave my steering wheel a tighten too, as it was starting to get a bit of play in the boss, so a few seconds with the allen Key fixed that Stuck down the badge too at work, with some primer and M3 tape. This wheel is a bit of a nightmare quality wise, i have had to glue down the fake leather part, with in a matter of months of owning the wheel. I may look at another wheel next year, but this one looks quite OEM for me, and its smaller making driving nicer too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
20th Jun 2021 1:48am |
Good bit of maintenance there on Beatie
It would pay to leave the carpet out until you have found the leak, no more damp smell Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
23rd Jun 2021 7:30pm |
Well today was a good day for beatie, Two upgrades to Beatie have happened!
One little treat for you lads, I bought this kit just before new year, and sort of did a rolling out installing it, as i had to replace a few parts of the dash, with the weather been spot on, my dad helped me do the final bits, He has been red hot on wanting to see the finished job, but has gave me some advice to check a few problems, as they are not working yet from that Click image to enlarge to this Click image to enlarge Also with the weather been great, my mum helped me fit these, which my sister got me for Xmas. Click image to enlarge Click image to enlarge And Beatie is a member of the club now! Click image to enlarge Click image to enlarge yeah the window seal has seen better days and so has the window screen, another job that i will have to do at some point. So tomorrow got to do some diag work on the spots, they are not powering on, so i am suspecting the fault is at the switch end or something. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
2nd Aug 2021 10:10pm |
sorted the spot lamp problem, i had the wire in the wrong pin, and one of the wires were not contacting the switch. A little bit of a shove with a very small screw driver and that was sorted.
They look great, my dad thinks they are better than his!, which i don't think so as his has a 3 way system dipped and full beam. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
3rd Aug 2021 11:17pm |
Nice additions there Procta and good you got the spots sorted out Clayton.
4th Aug 2021 7:50pm |
gave her a nice oil change and filters, found out that the back box is blown, in the same place my TDI was so i have ordered off a replacement a long with some rubbers. i will see about buying a good quality full system for this, scrap the cat etc. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
6th Aug 2021 1:45am |
Profyaffle Member Since: 03 Oct 2016 Location: N Yorks Posts: 527 |
Very nice... I keep contemplating some fog type lights ready for the fog we get here on the cold mornings.. Have you got a heated windscreen? worth upgrading if you are going to change anyway... 1993 200Tdi Defender 90 |
6th Aug 2021 8:33am |
Long time no see!!
yeah this one does have a heated window screen, has a chip in it sadly. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
6th Aug 2021 1:09pm |
Looks like Beatie has an Major oil leak, turns out the second mini oil filter housing the thread has gave way, and its been slightly open. A longer bolt in and a clean down, lets hope that sorts it. The remaining oil under the guard is going to make a mess at work! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
10th Aug 2021 8:23pm |
