Home > Td5 > TD5 18P engine
QuintinC
South Africa 2003 Defender 90 Td5 SW Alpine White
TD5 18P engine
I recently purchased a 2002 TD5 Defender 90. Manufactured in South Africa where I live. It has an 18P engine. I know that is not a common UK or EU engine designation, but was hoping someone could tell me whether or not that engine has EGR as standard. The only reason I ask is that I am overseas at the moment with no access to the car. I want to pick up an EGR blanking kit while I am in the UK but dont want to waste the cash if it was not fitted with EGR.
Post #767237 6th Apr 2019 7:03pm
landy andy
Never heard of 18p engine. 10 or 15 only.
Post #767239 6th Apr 2019 7:05pm
QuintinC
18P engine
The full engine number is 18P01162A as per registration papers
Post #767247 6th Apr 2019 7:17pm
landy andy
Thoughts would be that if a 15 had egr then anything after would. But it’s not necessarily that straight forward with LR. Only good point is egr blank is cheap.
Post #767249 6th Apr 2019 7:22pm
dorsetsmith
Is 18p engine not from Disco running high boost and injectors
you leary new land rover thing everyday 18p engine SA built Exclamation means disco with 18p engine in SA built too
Post #767255 6th Apr 2019 7:28pm
QuintinC
18P engine
Now that is very interesting. The VIN number has been confuring me. It is: SALLDVB772V847742
I am vey new to Land Rovers, but from the VIN number I understand the 8th letter in the sequence (7) to designate Discovery. Could it be that the South African manufactured Defenders used the Discovery engine?
Thanks for the replies by the way.
Post #767257 6th Apr 2019 7:38pm
I've seen 16P... you sure there's not just some muck making the number hard to read?
Post #767269 6th Apr 2019 8:57pm
grafty99
I've seen an 18P engine before. It was on an ex Mod 130 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #767274 6th Apr 2019 9:12pm
QuintinC
Will have to check this out when I get back home, but odd that there is also a discrepancy with the VIN
Will post the answers here.
In the meantime, before I spend £80 on the EGR blanking kit (and hoses) would it be safe to assume it has EGR?
Post #767275 6th Apr 2019 9:13pm
OsloBlue
18Ps only exist in South africa.
10Ps were global and 15Ps were the replacement but in south africa the 18P replaced the 10P, so might be a local build or maybe some special adaptions. All i know is that it uses metal dowels. It might be special air filtration or coling gear perhaps?
Some BMWs in SA have sumps with cooling fins on them. Lots of cars seem to omit EGR valves too.
19 - 24P also exist but seem to be a common LR Retrofit/Rebuild/Complete units for warranty work
Really curious. I'm on IG: https://www.instagram.com/osloblue42/
Post #767281 6th Apr 2019 9:25pm
QuintinC
Thanks guys, watch this space, I will share what I find out.
Post #767286 6th Apr 2019 9:33pm
QuintinC
I have heard from a knowledgable person that the 18P motor does NOT come with EGR fitted.
If there are any raises on that, let us all know.
Post #767323 7th Apr 2019 5:17am
mturri
 2006 Defender 110 Td5 CSW Bonatti Grey
Nothing in Microcat. EGR level and emission directive it conforms to would typically be listed under minor features and spec codes respectively.
However, a few levels down in the EGR parts section, part applicability appears to indicate that is fully Euro 3 compliant, that is, cooled EGR etc. Take this with a pinch of salt though...
 24 yrs of Td5 ownership
D110 Td5 MY06 fully tuned up
ex-D2 Td5 MY04 Auto
ex-D110 Td5 MY00
ex-D2 Td5 MY00
ex-D2 Td5 MY99
ex-D1 300Tdi MY89
ex-D90 200Tdi MY87
Post #767425 7th Apr 2019 3:57pm
QuintinC
Thanks again to all those who responded with advice.
The 18P motor was produced in South Africa and was not fitted with EGR. Metal dowels were used during manufacture as for 15P
Post #768070 10th Apr 2019 8:52pm
QuintinC
Post #768071 10th Apr 2019 8:53pm
