![]() | Home > Td5 > TD5 18P engine |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5853 ![]() ![]() |
Never heard of 18p engine. 10 or 15 only.
QuintinC Member Since: 06 Apr 2019 Location: Knysna Posts: 31 ![]() ![]() ![]() |
The full engine number is 18P01162A as per registration papers
Thoughts would be that if a 15 had egr then anything after would. But it’s not necessarily that straight forward with LR. Only good point is egr blank is cheap.
Is 18p engine not from Disco running high boost and injectors
you leary new land rover thing everyday 18p engine SA built ![]() Last edited by dorsetsmith on 11th Apr 2019 8:14pm. Edited 2 times in total |
Now that is very interesting. The VIN number has been confuring me. It is: SALLDVB772V847742
I am vey new to Land Rovers, but from the VIN number I understand the 8th letter in the sequence (7) to designate Discovery. Could it be that the South African manufactured Defenders used the Discovery engine? Thanks for the replies by the way. |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6162 ![]() ![]() ![]() |
I've seen 16P... you sure there's not just some muck making the number hard to read?
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4800 ![]() ![]() ![]() |
I've seen an 18P engine before. It was on an ex Mod 130
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Will have to check this out when I get back home, but odd that there is also a discrepancy with the VIN
Will post the answers here. In the meantime, before I spend £80 on the EGR blanking kit (and hoses) would it be safe to assume it has EGR? |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
18Ps only exist in South africa.
10Ps were global and 15Ps were the replacement but in south africa the 18P replaced the 10P, so might be a local build or maybe some special adaptions. All i know is that it uses metal dowels. It might be special air filtration or coling gear perhaps? Some BMWs in SA have sumps with cooling fins on them. Lots of cars seem to omit EGR valves too. 19 - 24P also exist but seem to be a common LR Retrofit/Rebuild/Complete units for warranty work Really curious. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
Thanks guys, watch this space, I will share what I find out.
I have heard from a knowledgable person that the 18P motor does NOT come with EGR fitted.
If there are any raises on that, let us all know. |
mturri Member Since: 13 Jul 2010 Location: All over Posts: 33 ![]() ![]() ![]() |
Nothing in Microcat. EGR level and emission directive it conforms to would typically be listed under minor features and spec codes respectively.
However, a few levels down in the EGR parts section, part applicability appears to indicate that is fully Euro 3 compliant, that is, cooled EGR etc. Take this with a pinch of salt though... ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 24 yrs of Td5 ownership D110 Td5 MY06 fully tuned up ex-D2 Td5 MY04 Auto ex-D110 Td5 MY00 ex-D2 Td5 MY00 ex-D2 Td5 MY99 ex-D1 300Tdi MY89 ex-D90 200Tdi MY87 |
Thanks again to all those who responded with advice.
The 18P motor was produced in South Africa and was not fitted with EGR. Metal dowels were used during manufacture as for 15P |
![]() Click image to enlarge Thanks again to all those who responded with advice. The 18P motor was produced in South Africa and was not fitted with EGR. Metal dowels were used during manufacture as for 15P |
