Home > Maintenance & Modifications > LOF POWERspring pedal assist
Page 14 of 14 <123 ... 121314
familymad
Mine felt like that but bedded in quickly and felt more natural 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #987929 4th Apr 2023 7:30pm
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
What is quickly? I've had the same feeling for more than half a year. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #987938 4th Apr 2023 8:48pm
They all do that - it's inherent in the design - but most people just get used to it. Darren
Post #987949 4th Apr 2023 9:54pm
Tdi4
Just my luck that I'am such a sensitive guy......
In other words I haven't gotten used to it yet. Let's give it another half year and worst case I just remove it. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #987985 5th Apr 2023 9:00am
Tdi4
* Double post * a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #987987 5th Apr 2023 9:02am
Landowner
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
Hi
I read conflicting info here, or perhaps the conflicting info is not about the lof spring but the mc?
Would the 2.2 Puma benefit from the lof spring? The one already fitted looks similar so I’m guessing the lof is a copy, but does it’s tension differ such that an improvement would be noticed?
I guess in short, are people fitting it to the 2.2 Puma?
Sorry to drag up such a debated subject again.
Post #989182 17th Apr 2023 2:40am
LR90XS2011
I think it is a case of giving it a bit of time and getting used to the difference, for me it has worked and my aching left knee is now complaining much less since I fitted mine DEFENDER 90 TDCI XS,
Post #989183 17th Apr 2023 6:34am
Naycrx
Don't suppose any body wants to fit mine for me for a case of beers !! Been trying to fit it for the last Hour and a half and failed using both methods! What a ball ache of a job ..... the U shaped bush snapped in the end so had to give up.... fitted the old one back for now......
Post #1018530 16th Dec 2023 6:27pm
Linds Hanson
Landowner wrote:
Hi
The LOF spring is a stronger version of the Land Rover genuine spring so can be fitted to all models from 300tdi onwards
Post #1018732 19th Dec 2023 3:48pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Finally got round to fitting my pedal spring yesterday lunch time, having watched Luke's fitting video, and convinced it would be done in double quick time, and still time left for a sandwich.
Original spring came straight out, U bush crumbled, tools assembled and found an L leg from my wife's gridwall system the perfect length for holding the clutch.
40 mins later I admitted defeat, rang my brother to ask if he could bring some needle nose mole grips home from work to drop in on his way past, and went and made a consolation sandwich, and further reading of this thread.
Stumbled across Roger's very informative post with pictures and decided cable ties was the answer, but with out the immediate access to a vice/quick clamp jury rigged a bar and 3 screw drivers to compress the spring to get zip ties in place. That eventually had to wait until my brothers arrival, where we then fought the spring for another 20 mins before giving up as the zip ties weren't up to the task.
My brother then went back to the brute force method, and 25 mins later it finally went in.
The difference is immediate, and when I eventually convince my wife to give driving the Defender another go, she'll find the clutch is much lighter. I'd even go to say that the old Fiesta she used to drive has a heavier clutch.
Wish I'd done it months/years ago (and paid someone else to do it) 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1034696 14th May 2024 9:51am
cjasmith97
United Kingdom 2009 Defender 110 Puma 2.4 CSW Keswick Green
I tried for hours, and in the end just got a local garage to sort it.
No regrets
Post #1037561 15th Jun 2024 10:22pm
shaynecm
I have the PowerSpec Master from LOF and found it didnt work with the spring as well - have the spring in the cubby box just incase of issues but running mine without a spring currently and is great.
just incase anyone buys the power+spring kit.
Post #1037671 17th Jun 2024 10:00am
