Home > Maintenance & Modifications > LOF POWERspring pedal assist
Page 9 of 14 <123 ... 8910 ... 121314>
Ndamico
Canada 2004 Defender 110 Td5 CSW Alpine White
Took it for a drive and the pedal sticks when I put it in gear and for a few seconds. Seems to stick less when i dont actually have it in gear. I like the softer pedal but I keep stalling it when the pedal sticks..then it unsticksvand pops the clutch lol
Post #783703 28th Jul 2019 11:30pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Fitted mine using the cable toe technique. Also bent the two flanges in slightly so the ends of the spring go through enough. Spring was moving to one side and I could not see the end of the spring past the plastic insert. Gave it a good squirt of white grease. Felt a bit sticky when pressed but after a few days that is no longer the case. I think I was over exerting pressure on it to begin with. Noticable difference......
Post #783747 29th Jul 2019 9:38am
RANGER1312
United Kingdom 2001 Defender 90 Td5 CSW Stornoway Grey
I know this is going to be a stupid question and I’ll pre-warn you that I’m not mechanically minded however I’ve purchased one of these and like most on here struggling to get it on so...
Got me thinking, I though clutches themselves have springs in them and once I removed the LR spring from the clutch pedal and the pedal works as normal so why not just remove the old one?
Is the clutch pedal spring just to stop rattles? Only asking as I’ve had to move the Defender without the new spring in and it drove fine Embarassed
Post #786251 11th Aug 2019 11:28am
RANGER1312
Managed to get it on, wow what a difference!! Cool
Post #786263 11th Aug 2019 1:17pm
Sulisuli
Glad you got it fitted ok Thumbs Up I too noticed a big difference having fitted one. 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #786265 11th Aug 2019 1:26pm
Def90
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Just an update on my findings after having the spring fitted for just over two weeks and a short 500 miles.
The pedal did get stuck down once or twice in the first week but now I have got used to the lighter feeling pedal it’s not really been a problem.
I have to agree it feels much better now and an improvement over the standard spring, with the added bonus of smoother gear changes.
I would also suggest that you giving it a few days and see how you get on with the new pedal feel!
Post #786298 11th Aug 2019 4:01pm
AJC
Has anyone left the horse shoe bush off the back of the clutch pedal? I can’t get mine to slide all way down the recess in the clutch arm.
Post #786303 11th Aug 2019 4:34pm
stephan123
Had one fitted over the weekend to MY2015 truck. Noticeable improvement. Makes for smoother gear changes and I find it really compliments my ECU remap and slickshift. Well worth doing. On a side note i found the clutch pedal did initally have a sticky feel becasue i was pressing too hard. Soon got used to it and no issues since Thumbs Up
Post #786451 12th Aug 2019 12:27pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
LOF spring
Had mine fitted this morning by Mastora Alnwick what a difference (couldn't fit due to arthritis)
Post #786952 15th Aug 2019 11:49am
Sulisuli
One of the cheapest and best mods I have done, such a noticeable difference between driving mine with it fitted and the wife’s which doesn’t have one Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #786959 15th Aug 2019 11:57am
Naks
Not sure how you guys managed to fit this, but I dropped by my indie this afternoon because he was excited to fit one.
90 min and much swearing later, we admitted defeat and put the old spring back in Shocked
the plan is to remove the pedal box and then fit it on the bench, unless there's a foolproof way to do it in situ? --
Post #797282 8th Oct 2019 4:20pm
PCM
I needed a metal tye wrap and a vice to squeeze it in.
Plastic tye wraps just snapped.
Post #797296 8th Oct 2019 5:36pm
mick
I’ve a LOF clutch fitted and the pedal is really nice on its own
Post #797304 8th Oct 2019 6:04pm
Naks
Many, many cable ties later, the workshop finally got it in!
Big difference to the clutch action, well worth the 20 pounds Thumbs Up --
Post #797833 12th Oct 2019 10:24am
Pilgrimmick
I have a very heavy duty clutch fitted due to an engine power upgrade, have the LOF spring AND a servo fitted, still a heavy clutch, but almost solid without them! 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #797997 13th Oct 2019 8:00pm
