![]() | Home > My Defender > Utility sound proofing recommendations |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2939 ![]() ![]() |
I tried skinz in the roof. When I went to install the DVD player and took the headlining down it had all melted and dropped off the roof skin so I replaced it with dynamat extreme with no more issues. Andy
2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5824 ![]() ![]() |
My Td5 utility.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 747 ![]() ![]() ![]() |
Looks amazing. What soundproofing and other materials did you use?
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
Are they the tge side panels?
Did you just screw the storage nets into them? |
I bought car carpet off eBay and made the panels from 12mm ply that I bonded in place with Pu sealer. Then put the CSW trims on. That way I can screw anything I want to them. They are solid, and insulated.
Before. ![]() Click image to enlarge |
When I did mine, I used a combination of Silent Coat noise deadener, covered with 6mm closed cell foam. It totally transformed it.
More details HERE. ![]() Click image to enlarge ![]() Click image to enlarge Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
That popular treatments are acoustic material (dynamat/skinz etc), 6mm closed cell foam then rubber matting.
For a more utilitarian finish you could go for an acoustic lineX/Raptor bedliner type paint. Have a look at Buzzweld. Welcome to D2N and Defender ownership! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Thanks guys, just what I needed. Some amazing work there....
kaney Member Since: 01 Oct 2018 Location: Bolton Posts: 232 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() Click image to enlarge I put 10mm stick on which has made a big difference which i got off Amazon but now has finished stocking but i have seen it for sale elsewhereMayuber 10sqm Aluminium Foil Insulation Liner for Van Car Vehicle Thermal Soundproof Foam 1m x 10m then added ply on top ready for shelving ![]() Click image to enlarge Obviously this is for work but you could copy and add the accoustic on the plywood without the shelving |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
One of these https://www.easimat.com/acatalog/22mm-EVA-...tml#SID=55 cut to size and fitted under the rubber floor mat in the load area makes a lot of difference
Does anyone know how many meters squares of insulation I need for a 110 station wagon. I’ll totally strip out the interior so want to be prepared.
I used 1mtr x 10 mtr roll as in the pics just above i did all the back inc roof and under the rear floor board and front mats if that helps
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
I did the "entire" interior and bonnet of a 110 CSW and used 3mm silent coat in black.
Used 2.2 boxes of the multi pack so you may need three as you have no windows. Also lined the roof and sides in the 15mm egg shell closed cell foam. Used 2 packs and did the roof, sides and doors on top of the 3mm stuff. Biggest trick was to heat the car interior up or is doesn't stick when cold. Call them up and they are really helpful and will give you a decent multipack buy. Links are below: https://www.deadening.co.uk/products/silent-coat-absorber https://www.deadening.co.uk/products/silen...-bulk-pack |
Heres another tip if you have some left over and put some under the front mats don't stick it down as water will at some point get there and you can't wipe it up if it gets under between that and the metal floor will obviously rust
