Home > My Defender > Utility sound proofing recommendations
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
As you guys are the experts I'm hoping you can help. Just bought my first defender. A 2010 2.4Tdci 5 seat utility station wagon. It's an Oz import that lived in Sydney for its first 8 years so great condition.
I'm looking for recommendations for the best soundproofing in the back as currently just painted steel. Once sound proofing what do you guys use to protect it? It will be used as a weekend car so normal kids bikes and wellies in the boot plus talk of a puppy soon. I was thinking of ply lining it.
Any photos would be great.
Post #757587 9th Feb 2019 6:10pm
mcma1
I tried skinz in the roof. When I went to install the DVD player and took the headlining down it had all melted and dropped off the roof skin so I replaced it with dynamat extreme with no more issues. Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #757600 9th Feb 2019 7:30pm
landy andy
My Td5 utility.
Post #757612 9th Feb 2019 8:18pm
boxoftricks
Looks amazing. What soundproofing and other materials did you use?
Post #757618 9th Feb 2019 8:26pm
Sphere
United Kingdom 2015 Defender 110 Puma 2.2 USW Keswick Green
Are they the tge side panels?
Did you just screw the storage nets into them?
Post #757621 9th Feb 2019 8:32pm
landy andy
I bought car carpet off eBay and made the panels from 12mm ply that I bonded in place with Pu sealer. Then put the CSW trims on. That way I can screw anything I want to them. They are solid, and insulated.
Before.
Post #757631 9th Feb 2019 8:45pm
When I did mine, I used a combination of Silent Coat noise deadener, covered with 6mm closed cell foam. It totally transformed it.
More details HERE.
 Darren
Post #757639 9th Feb 2019 9:07pm
JOW240725
That popular treatments are acoustic material (dynamat/skinz etc), 6mm closed cell foam then rubber matting.
For a more utilitarian finish you could go for an acoustic lineX/Raptor bedliner type paint. Have a look at Buzzweld.
Welcome to D2N and Defender ownership! James
Instagram @suffolk_rovers
Post #757640 9th Feb 2019 9:10pm
boxoftricks
Thanks guys, just what I needed. Some amazing work there....
Post #757642 9th Feb 2019 9:15pm
kaney
United Kingdom 2005 Defender 90 Td5 CSW Epsom Green
I put 10mm stick on which has made a big difference which i got off Amazon but now has finished stocking but i have seen it for sale elsewhereMayuber 10sqm Aluminium Foil Insulation Liner for Van Car Vehicle Thermal Soundproof Foam 1m x 10m then added ply on top ready for shelving
Obviously this is for work but you could copy and add the accoustic on the plywood without the shelving
Post #757649 9th Feb 2019 9:56pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
One of these https://www.easimat.com/acatalog/22mm-EVA-...tml#SID=55 cut to size and fitted under the rubber floor mat in the load area makes a lot of difference Thumbs Up
Post #757655 9th Feb 2019 10:23pm
boxoftricks
Does anyone know how many meters squares of insulation I need for a 110 station wagon. I’ll totally strip out the interior so want to be prepared.
Post #757663 9th Feb 2019 11:32pm
kaney
I used 1mtr x 10 mtr roll as in the pics just above i did all the back inc roof and under the rear floor board and front mats if that helps
Post #757674 10th Feb 2019 7:49am
PCM
I did the "entire" interior and bonnet of a 110 CSW and used 3mm silent coat in black.
Used 2.2 boxes of the multi pack so you may need three as you have no windows.
Also lined the roof and sides in the 15mm egg shell closed cell foam. Used 2 packs and did the roof, sides and doors on top of the 3mm stuff.
Biggest trick was to heat the car interior up or is doesn't stick when cold.
Call them up and they are really helpful and will give you a decent multipack buy. Links are below:
https://www.deadening.co.uk/products/silent-coat-absorber
https://www.deadening.co.uk/products/silen...-bulk-pack
Post #757680 10th Feb 2019 8:31am
kaney
Heres another tip if you have some left over and put some under the front mats don't stick it down as water will at some point get there and you can't wipe it up if it gets under between that and the metal floor will obviously rust Big Cry
Post #757726 10th Feb 2019 12:09pm
