Home > My Defender > Fuji 110 LS3 build
Page 63 of 64 <123 ... 626364>
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
mcma1 wrote:
The rear camera? I will likely place it on the roof. I am really doing this to gain the reverse camera function without having a double din install, dash cam recording is just a bonus!
Got some M2 screws and could finally fit it up. Visors can got to vertical only as expected so I am going to buy some used ones from ebay tonight and cut/retrim them.
The only negative beyond my control is the cable connections to the Wolfbox as they slot into the top so I am going to print a small cap/cover to hide them.
Into the headlining I have beefed up 2 of the 3 bolts holding the mirror bracket so that I can lose the 3rd bolt and dremel out a channel for the cables to feed up thru the bracket. I think this is about the best I can do given what i started with.
Lovely job.
I can’t remember where I saw it but to hide the wiring somebody 3D prints a plate with a channel for the wires that sits under the 3 screws. WARNING.
This post may contain sarcasm.
Post #1058384 23rd Jan 2025 10:31pm
pistonfields
Switzerland
Thanks for de detailed explanation. yes, the rear view camera. PO mounted one under the spare wheel on the tailgate. I likely would only use it when parking, so no need for me to see the tow hitch.
The 3d printed part looks brilliant, very well done. Would you mind sharing the 3d files? Then I could fire up my own printer if I get myself that rear view mirror... wife has been complaining recently how usefull it would be. Guess I'm cleared to spend the money then Very Happy
Post #1058412 24th Jan 2025 9:10am
mcma1
Let me get it all fully fitted and then I can help out.
What would people say is the best view from a rear camera? I don’t need to see the towbar so I guess if I just catch the edge of the spare? Has anyone any pictures of there rear camera view on screen to share before I fix it to the roof?? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1058532 25th Jan 2025 11:19am
NoLimits
United Kingdom 2013 Defender 110 Puma 2.2 USW Havana
You can scroll up and down on the screen to adjust the angle, I mounted mine high up by modifying the rear washer with 2 cameras, one as a rear view and the other to look down to the tow bar (I currently don’t have a wheel on the back)
This image shows the screen in its central spot looking straight out but it does have about 10 degrees of angle up and down, the picture also shows the reversing camera on the main screen, beware that even up there they do get dirty. I used to have one below the spare wheel and that would become useless after a few miles in the winter.
I used Ram mounts to fix mine up and at some point I will directly wire those cables in through the back of the unit
Hope that helps
Post #1058643 26th Jan 2025 12:45pm
mcma1
Thanks for this, didnt know the angle had some adjustment in the setting Thumbs Up Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058644 26th Jan 2025 12:51pm
mcma1
Another update on the most over engineered Wolfbox install Rolling with laughter Just got the power back on since Thursday night after the storm.
The modified leg so that the cables can pass thru it...
Then printed a connector cover which is still to be painted.
Some printed spacers so the cables can run behind the mount
So pretty much ready to fit it all up now. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058680 26th Jan 2025 7:45pm
L110CDL
Loving this Andy, the fit will be spot on Very Happy Clayton.
Keeper.
Post #1058751 27th Jan 2025 9:19pm
mcma1
Thanks Clayton. Got it fitted this evening, just the hardwire power to hook up next. Thumbs Up
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058759 27th Jan 2025 10:43pm
L110CDL
wow, as always, the attention is in the detail Very Happy Clayton.
Keeper.
Post #1058926 29th Jan 2025 9:57pm
mcma1
So all fitted and hard wired in now. Took a bit longer as I needed to add some extra wires from the new bluesea fuse box for this and the winch cut off which I plan to finish tomorrow.
Printed a mount for the rear camera..
GPS located here..
Used visors from Ebay trimmed to suit..
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1059180 1st Feb 2025 5:17pm
mcma1
Got to fit some leather this evening. Very pleased. Just some black nappa on the usual bits and perforated grab handle to match the adventure steering wheel. The sliding cubby lid is a hit, just needs to sit over night while its bonded on, rear cubby to do in the morning and then new seat belts. The only thing that didn't work out was the leather gaiter for the gear stick. I just don't have the space to gather all the leather so I may have an alloy surround machined with a simple slot for the travel and maybe add some letters for the positions, not sure Confused
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1059737 6th Feb 2025 10:40pm
mcma1
Wee handy job this morning to fit the rear cubby. Its a standard cubby I modified, not as wide and floats over the sub. Then just a precision cut of a cup holder on the chop saw to fit it into place.
4x4 works have just got some nice warn accessories into stock as i have been looking for a bag for the remote and gloves. Went for the grab handle bag in the end on the rear door.
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1059946 8th Feb 2025 2:13pm
mcma1
Fitted the Porsche Chalk belts today, nice to see a bit of contrast inside. Top class service as always from FDTS. Thumbs Up
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1060720 16th Feb 2025 7:59pm
keith
Is there anyway of mounting the wolf mirror above the sun visors either using the mirror mount or any other means? Iv always taken my rear view mirror off as it gets in the way as a huge windscreen view obstruction?
Keith.
Post #1060796 17th Feb 2025 8:31pm
keith
Keith.
Post #1060797 17th Feb 2025 8:32pm
