Home > My Defender > Fuji 110 LS3 build
Page 63 of 63 <123 ... 616263
Zed
mcma1 wrote:
The rear camera? I will likely place it on the roof. I am really doing this to gain the reverse camera function without having a double din install, dash cam recording is just a bonus!
Got some M2 screws and could finally fit it up. Visors can got to vertical only as expected so I am going to buy some used ones from ebay tonight and cut/retrim them.
The only negative beyond my control is the cable connections to the Wolfbox as they slot into the top so I am going to print a small cap/cover to hide them.
Into the headlining I have beefed up 2 of the 3 bolts holding the mirror bracket so that I can lose the 3rd bolt and dremel out a channel for the cables to feed up thru the bracket. I think this is about the best I can do given what i started with.
Lovely job.
I can’t remember where I saw it but to hide the wiring somebody 3D prints a plate with a channel for the wires that sits under the 3 screws. WARNING.
Post #1058384 23rd Jan 2025 9:31pm
pistonfields
Switzerland
Thanks for de detailed explanation. yes, the rear view camera. PO mounted one under the spare wheel on the tailgate. I likely would only use it when parking, so no need for me to see the tow hitch.
The 3d printed part looks brilliant, very well done. Would you mind sharing the 3d files? Then I could fire up my own printer if I get myself that rear view mirror... wife has been complaining recently how usefull it would be. Guess I'm cleared to spend the money then Very Happy
Post #1058412 24th Jan 2025 8:10am
mcma1
Let me get it all fully fitted and then I can help out.
What would people say is the best view from a rear camera? I don’t need to see the towbar so I guess if I just catch the edge of the spare? Has anyone any pictures of there rear camera view on screen to share before I fix it to the roof?? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1058532 25th Jan 2025 10:19am
NoLimits
United Kingdom 2013 Defender 110 Puma 2.2 USW Havana
You can scroll up and down on the screen to adjust the angle, I mounted mine high up by modifying the rear washer with 2 cameras, one as a rear view and the other to look down to the tow bar (I currently don’t have a wheel on the back)
This image shows the screen in its central spot looking straight out but it does have about 10 degrees of angle up and down, the picture also shows the reversing camera on the main screen, beware that even up there they do get dirty. I used to have one below the spare wheel and that would become useless after a few miles in the winter.
I used Ram mounts to fix mine up and at some point I will directly wire those cables in through the back of the unit
Hope that helps
Post #1058643 26th Jan 2025 11:45am
mcma1
Thanks for this, didnt know the angle had some adjustment in the setting Thumbs Up Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058644 26th Jan 2025 11:51am
mcma1
Another update on the most over engineered Wolfbox install Rolling with laughter Just got the power back on since Thursday night after the storm.
The modified leg so that the cables can pass thru it...
Then printed a connector cover which is still to be painted.
Some printed spacers so the cables can run behind the mount
So pretty much ready to fit it all up now. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058680 26th Jan 2025 6:45pm
L110CDL
Loving this Andy, the fit will be spot on Very Happy Clayton.
Keeper.
Post #1058751 27th Jan 2025 8:19pm
mcma1
Thanks Clayton. Got it fitted this evening, just the hardwire power to hook up next. Thumbs Up
 Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1058759 27th Jan 2025 9:43pm
L110CDL
wow, as always, the attention is in the detail Very Happy Clayton.
Keeper.
Post #1058926 29th Jan 2025 8:57pm
