Home > Td5 > TD5 Driver Demand
Page 4 of 5 <12345>
TJ101
Thanks all,, Not had a chance to look at it since the weekend, Shocked bar moving it Monday morning, and of course, it was all fine then, after limping home all the way Sunday Evil or Very Mad
Any Nanacom Experts ?? Getting info to the unit, (old style great box one) & Driver Demand, but tried to get it to talk to a laptop, and can't find com port , even tried a 2nd toughbook, and same issue Shocked California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #751840 17th Jan 2019 10:12am
TJ101
OK So Far
All New Genuine
Throttle pedal
Map Sensor
Crank sensor (gen at £220 odd plus vat !!!!)
New complete loom from pedal to ecu, with new pedal plug
Just been on its 4th trip,, 7 miles and still the same, another recovery back home Evil or Very Mad Evil or Very Mad Sad
Just about lost the love for this one now,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #754762 29th Jan 2019 2:08pm
jst
£3k buy it now? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #754847 29th Jan 2019 9:10pm
TJ101
Can,t charge you that much for just the rims and tyres , California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #754872 29th Jan 2019 10:08pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I had a issue with the transfer box switch. It caused havoc with mine in the wet, loss of power misfires/hiccups and throttle lag it also had problems with the difflock light coming on too in the damp which I changed at the same time
On a td5 it switches maps when low range is selected. Anyway long story short it was getting damp and going closed and open circuit. I followed the wiring back and bridged it so I have one map all the time. Sorted mine out.
Easy and cheap thing to have a go at. 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #754874 29th Jan 2019 10:30pm
lightning
Both my TD5’s (one bought new) also switch over to the low range map if you apply full throttle while in high range. On the new one l tried to get it sorted, but had no luck.
My 2005 110 has always done it. Is there a solution to this? It’s a pain on the motorway as your foot gets tired from holding the throttle pedal further down in order to maintain speed.
Post #754919 30th Jan 2019 9:05am
gazman
Disconnect the switch on the TX box and it's one map all the tine 2014 - current ..... 2003 defender td5 90 (my car)
Post #754921 30th Jan 2019 9:12am
landy andy
Wow I can’t believe the price of the crank sensor. I’m sure they were a relatively cheap item, I used to just have a spare knocking about.
I can only think it’s your ECU. I can’t see what else would give you such a random, non constant fault.
Post #754925 30th Jan 2019 9:25am
TJ101
Thanks Guys
LR Genuine crank sensor £231.35 plus the vat copy ones £25-40 !! anyhow gen gone in, and no difference
Will look at TB switch,,
Andy,, my though as well ? so at present have "borrowed " a disco td5 ecu,, and it running again, but a tad rough, but not showing the same problem, Just fuel and temp gauges a bit iffy
Anyone got a Def ecu i can hire,borrow,nick, to test California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #754930 30th Jan 2019 9:43am
landy andy
Sounds like the ECU then. Reg the rough running did you reprogram the injectors?
I can’t believe it would be any thing simple to be such an erratic fault. Often tuners have spare ECUs that they lend out. Or stick a wanted add in the sales section.
Post #754941 30th Jan 2019 11:08am
gazman
The rough running will be because it has the wrong codes for the injectors 2014 - current ..... 2003 defender td5 90 (my car)
Post #754988 30th Jan 2019 3:31pm
TJ101
Correct,,, Did not bother doing the injectors, runs ok, for test purposes Smile
Got home last nigh, and back into office this morning !!! but that is only 5 miles both ways max !!!
I have no idea who's map is on the ecu, This was David Bowyer, Goodwinch 90, they used to tow the display trailer to shows etc, doubt its ever been off road, and the map is written for towing
Off to do a wanted add Smile California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #754992 30th Jan 2019 3:54pm
TJ101
Update
So, 5 mile round trip home and back the other evening with the std disco ecu,, all good
Just done about 25 miles to Chard with the same ecu,, iffy gauges and poor low down power delivery, but it did get there,
Fitted a D2 NNN ecu, with a map to try, switched the pedal from 2 position to 3, now have proper tickover/low speed, gauges that work, and good top end power,,, more importantly,, it got me 25 miles home again Smile
So, looking like a very intermittent ECU fault ? Question California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #755281 31st Jan 2019 5:38pm
MadTom
I have repaired a few TD5 ECUs with broken component (SMD resistors) inside or with bad solder joints. Probably poor soldering, but because the ECUs were working for more than 10 years, there was no way, how to find this problem during the ECU manufacturing.
It is not easy to find problems like these, especially, when they are intermittent. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #755285 31st Jan 2019 5:50pm
TJ101
Update i guess
Did aprox 200 miles in the snow for Wessex, moving Doctors/Nurses etc,, all no problem
Do 10 miles maybe yesterday, down motorway, then on to the north devon link road,,
Slap bang in the contraflow,, and does the same again Misfire, hestiantant , all as before !!!
So, back to square one Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #757758 10th Feb 2019 2:47pm
Page 4 of 5 <12345>
