![]() | Home > Td5 > TD5 Driver Demand |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
OK So Far
All New Genuine Throttle pedal Map Sensor Crank sensor (gen at £220 odd plus vat !!!!) New complete loom from pedal to ecu, with new pedal plug Just been on its 4th trip,, 7 miles and still the same, another recovery back home ![]() ![]() ![]() Just about lost the love for this one now,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
£3k buy it now? Cheers
Can,t charge you that much for just the rims and tyres , California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 ![]() ![]() ![]() |
I had a issue with the transfer box switch. It caused havoc with mine in the wet, loss of power misfires/hiccups and throttle lag it also had problems with the difflock light coming on too in the damp which I changed at the same time
On a td5 it switches maps when low range is selected. Anyway long story short it was getting damp and going closed and open circuit. I followed the wiring back and bridged it so I have one map all the time. Sorted mine out. Easy and cheap thing to have a go at. 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2946 ![]() ![]() |
Both my TD5’s (one bought new) also switch over to the low range map if you apply full throttle while in high range. On the new one l tried to get it sorted, but had no luck.
My 2005 110 has always done it. Is there a solution to this? It’s a pain on the motorway as your foot gets tired from holding the throttle pedal further down in order to maintain speed. |
Disconnect the switch on the TX box and it's one map all the tine 2014 - current ..... 2003 defender td5 90 (my car)
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Wow I can’t believe the price of the crank sensor. I’m sure they were a relatively cheap item, I used to just have a spare knocking about.
I can only think it’s your ECU. I can’t see what else would give you such a random, non constant fault. |
Thanks Guys
LR Genuine crank sensor £231.35 plus the vat copy ones £25-40 !! anyhow gen gone in, and no difference Will look at TB switch,, Andy,, my though as well ? so at present have "borrowed " a disco td5 ecu,, and it running again, but a tad rough, but not showing the same problem, Just fuel and temp gauges a bit iffy Anyone got a Def ecu i can hire,borrow,nick, to test California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
Sounds like the ECU then. Reg the rough running did you reprogram the injectors?
I can’t believe it would be any thing simple to be such an erratic fault. Often tuners have spare ECUs that they lend out. Or stick a wanted add in the sales section. |
The rough running will be because it has the wrong codes for the injectors 2014 - current ..... 2003 defender td5 90 (my car)
Correct,,, Did not bother doing the injectors, runs ok, for test purposes
![]() Got home last nigh, and back into office this morning !!! but that is only 5 miles both ways max !!! I have no idea who's map is on the ecu, This was David Bowyer, Goodwinch 90, they used to tow the display trailer to shows etc, doubt its ever been off road, and the map is written for towing Off to do a wanted add ![]() Main Brian James Trailer Dealer for South West UK |
Update
So, 5 mile round trip home and back the other evening with the std disco ecu,, all good Just done about 25 miles to Chard with the same ecu,, iffy gauges and poor low down power delivery, but it did get there, Fitted a D2 NNN ecu, with a map to try, switched the pedal from 2 position to 3, now have proper tickover/low speed, gauges that work, and good top end power,,, more importantly,, it got me 25 miles home again ![]() So, looking like a very intermittent ECU fault ? ![]() Main Brian James Trailer Dealer for South West UK |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 639 ![]() ![]() ![]() |
I have repaired a few TD5 ECUs with broken component (SMD resistors) inside or with bad solder joints. Probably poor soldering, but because the ECUs were working for more than 10 years, there was no way, how to find this problem during the ECU manufacturing.
It is not easy to find problems like these, especially, when they are intermittent. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo ![]() |
Update i guess
Did aprox 200 miles in the snow for Wessex, moving Doctors/Nurses etc,, all no problem ![]() Click image to enlarge Do 10 miles maybe yesterday, down motorway, then on to the north devon link road,, Slap bang in the contraflow,, and does the same again Misfire, hestiantant , all as before !!! So, back to square one ![]() ![]() ![]() ![]() Main Brian James Trailer Dealer for South West UK |
