![]() | Home > Td5 > TD5 Driver Demand |
kevinp Member Since: 30 Dec 2015 Location: west sussex Posts: 5 ![]() ![]() ![]() |
had a similar problem on mine would just go to limp mode then clear or would suddenly give me a really lazy throttle after months of looking bought a hawkeye and watched sensors when it happened found it was temp side of map sensor limp mode it would jump from 28 degress to 136 then would drop back to 28 and run fine and if it went the other way -35 lazy throttle ,new sensor sorted
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Thanks guys... Not had a chance to look at it as yet,, will be weekend at the earliest,, Autosport show from Thursday on
Ordered a genuine Map sensor, Plus a good friend, ![]() Main Brian James Trailer Dealer for South West UK |
dkmlondon Member Since: 15 Jun 2018 Location: London and Somerset Posts: 14 ![]() ![]() ![]() |
Hi TJ101
Reading your thread with interest. Have an occasional starting issue on my Td5 110 CSW MY2006, when cold, with the well-reported chugging and no pick-up. Injector seals done, MAF new, ECU wiring clear, EGR removed, decent map (Stage 2 by JE Engineering) with uprated cooler quiet fuel pump etc etc but she will still protest when cold (like the rest of the family!) but eventually agrees to participate. Am living with it pro tem, but would love a solution! Other reason for post is to offer use of my Nanocom - am not far from Taunton, and always good to share one's weaknesses and addictions! It is a really useful addition. PM me if of any interest or your mate's doesn't arrive. DM |
Thanks DM
Been up at Autosport show all day, and see friends units has arrived, plus a gen Map sensor , Hopefully may get a chance to have a look tomorrow ? have a use for the 90 on Sunday Drive round day ![]() PS Welcome to the D2 forum ![]() Main Brian James Trailer Dealer for South West UK |
Many thanks for the welcome - have been a td5 owner for about 15 years, (and RRC many years ago when they were new...!) and am enjoying exploring the distant corners of Landy-lore as a newb!
Is there a Sunday Drive in Somerset? |
Next event that your 110 will be ok with is
https://www.defender2.net/forum/topic65403.html A 110, on Sundays Drd,, even though they have been round before would not be ideal https://www.4x4adventures.co.uk/_main/drive_round_days.htm California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
At the risk of heading off topic
![]() Will enter negotiations and respond via website. Many thanks for the steer. ![]() |
Update
Well, 3rd trip out on a Drive round day,, 3rd time it played up,, Mil light on, and no throttle,switch off and restart ok,but same misfire, and non driveability Fitted a new gen Map sensor there and then made no difference, checked live values via nanacom,, all looked ok, certainly the pedal values Earthing points next call ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5859 ![]() ![]() |
Wasn’t there an issue with earth to the fuses, and relays under driver seat that caused problems in the past?
Think it always made the temp gauge shoot up thpugh, and you’d have noticed that. |
Hi Andy
Temp gauge is working, and tests ok, via Nanacom Could be a coincidence , when it played up yesterday, i noticed the difflock light on 3rd brightness ? hence thinking earths ? saying that, the light did then come on as it should, but problem still there So,, start in fusebox !, fault is so intermittent,, was fine driving to the venue, and for the first hour or so,, then limp all the way home !!! looking for all the downhill bits, Mil light coing on quite often, needed a rolling switch off and restart ![]() Main Brian James Trailer Dealer for South West UK |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2206 ![]() ![]() ![]() |
Upsetting!
Tried the crank sensor? |
If you do swap/check the crank sensor look for the spacer that might be there or damage to the end of the sensor due to spacer being required.
I don’t know why some need spacer and others don’t. |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 645 ![]() ![]() ![]() |
Bad engine ECU - I have repaired domě TD5 ECUs with blown components in crank sensor circuit. Domě tiny parts were broken. All cars had problems with crank sensor signal, all had tried new sensor s and spacers. Car were tuning, but not optimal. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
dont forget the DRL flicker when you winch too, also links to earthing? Cheers
