Home > Maintenance & Modifications > Updated headlamps in reality ?
Page 3 of 4 <1234>
redline
Switzerland
JWS dual-burn heated headlights are now up on the Nakatenenga site at an eye watering €1,060 or £960... Shocked
As fancy as they are, I'll be sticking to my Crystals then...
Post #746594 20th Dec 2018 1:16pm
Mo Murphy
So cheap no one on here will take them seriously Wink
50 Shades of Pennine Grey
Post #746616 20th Dec 2018 4:07pm
Grouse
Agreed there 100%, we are driving a Land Rover - upgrading to Wipacs and Nightbreakers is more than ample - spending £hundreds on LED’ s is totally pointless, gain virtually nothing and look awful like a cheap biscuit tin out of a Darth Vader movie.
Post #746689 21st Dec 2018 12:26am
Mother superior
Gents
I went down the HID route, quite happy with them as they match my LED side lights pretty well and give a good output.
I got mine from HIDS4U over on the D3 forum Oh woe, oh woe
My crusty old landrover,
It will not go.
Post #746931 22nd Dec 2018 8:30pm
^^^ How did you make them legal?
Post #746933 22nd Dec 2018 9:06pm
leeds
Do not be tempted to fit a HID conversion kit into a headlight designed for halogen filament bulb as it is illegal. Taken from the Hids4u website
Quote:
Is HID xenon Legal?
Unfortunately no aftermarket HID kit is strictly road legal as you are changing the lighting system (from halogen to gas discharge) in your car and for this reason the bulbs can't be E marked which is a legal requirement. You also won't have the self leveling and washer systems installed which is also a legal requirement for HID and without these installed the kit would be an MOT failure. HID kits are plug and play so they are easy to remove and replace with standard bulbs come MOT time.
So they are admitting that their kits are illegal why else taken them out for a MOT?
Taken from the MOT testers manual section 4.1.4 [url=https://www.mot-testing.service.gov.uk/documents/manuals/class3457/Section-4-Lamps-reflectors-and-electrical-equipment.html#section_4.1]here[url]
Quote:
Existing halogen headlamp units shouldn’t be converted to be used with HID bulbs. If such a conversion has been done, you must fail the headlamp.
Now the UK Vehicle Lighting Regulations clearly state that headlights must carry an approval mark. Part of the approval mark is the light function code
Class CR or C/R are tungsten filament lamps
HCR or HC/R is normally LED
DR or DCR is normally HID
Fit a different light source in a headlamp and approval mark is void
Also a MOT major defect
Quote:
Light source and lamp not compatible . Major . Defect
The ONLY legal way to change the type of light source in a headlamp is to replace the whole unit for one which has the correct genuine approval markings on.
Brendan
Post #746938 22nd Dec 2018 9:24pm
Jas Ardis
United Kingdom 2012 Defender 110 Puma 2.2 USW Auto Stornoway Grey
In terms of cost effectiveness they’re way down there with lights that are cheap and rubbish. I think some folk are laughing their way to the bank. Rolling with laughter A grand? Really? Let’s put that in the tank and go some place we’ve never been. Even if it’s at circa 20 mpg.
Post #784587 2nd Aug 2019 9:05pm
90 Dreamer
Have always used PIAA bulbs in other vehicles and in approx 15+yrs have only ever had 1 bulb fail.......
Post #784591 2nd Aug 2019 9:21pm
Banbury
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
leeds wrote:
To the best of my knowledge neither Nolden or Vision X does not have a heated 7" LED headlight
Truck-Lite do a 7" heated LED headlight but it is not approved for road use in Europe (not UNECE approved) It is approved for road use in America as it is DOT compliant
J W Speaker do have a heated 7" LED headlight which is both DOT approved for use in America and has UNECE approval for use in Europe. Available in RHD UK specification for about a £1,000 and LHD European specification. Not sure on price in Europe. Have a look here
Brendan
Yep. I have those JW Speaker LEDs with the heat function (“SmartHeat® Headlights - JW Speaker Dual Burn (DRL)”.
How can I say this - they are awfully bright - but are installed not to dazzle. The engineers who fitted them made sure they were setup correctly. Great at night and the DRLs look quite fetching in the day.😊
Post #784729 3rd Aug 2019 9:57pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Over the years I have tried many a different types just to get the most light on the road as street lights are a uncommon sight out here in the sticks. From the days of using relays and Ring Rally sport 130 watt bulbs, to being legal and using the crystals and the GE megalight bulbs, I relented and went Trucklite after a headlight relay burned out.
Even though some might argue that the trucklite isn't the brightest HL The overall experience is far beyound what the older fillament bulbs could produce, Nice colour light with good spread, not to mention a sealed unit that won't let water in when wading. I have written off a few bulbs with sub aqua endevours. Whistle
A family member ran crytals and a retro fit HID kit and all it gives a Dazzaling puddle of light with no aim or discernable beam pattern. yes it was bright but in the rear view or heading towards him it was dangerous and unsafe.
LED are a expensive upgrade granted but I feel the benefits work well. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest
Post #784806 4th Aug 2019 11:26am
That's not surprising . Retro fit HID kits are illegal for exactly that reason. Darren
Post #784816 4th Aug 2019 11:54am
90 Dreamer
stooopid question time but looking at the front it appears you have to remove the lamp assembly to change the bulbs???
is that right or am i missing something??
Post #784980 5th Aug 2019 12:51pm
Sulisuli
Your correct 90 Dreamer Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #784984 5th Aug 2019 12:57pm
MartinK
So I have been on a route of Wipac Crystal with +130% Osram nightbreaker.
Now have Trucklite LED with the uprated Land Reizger loom.
In honesty, i think the nightbreakers with Wipac Crystal plus loom upgrade are as good as anything.
My LED's seem to be better in some ciscumstances, but less good in others. Terrible in falling snow for instance, the LED causes a lot of reflected glare.
In hindsight nightbreakers with Wipac Crystal plus loom upgrade are as good as anything.
One benefit of the LED's I have is they don;t need masking for overseas use, the cut-off is flat. Plus they have bright sidelights - almost of DRL quality Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #784989 5th Aug 2019 1:28pm
90 Dreamer
cheers, is it the whole lamp surround or just the lamp lens??
Post #785008 5th Aug 2019 2:53pm
Page 3 of 4 <1234>
