Home > Maintenance & Modifications > Updated headlamps in reality ? |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
So cheap no one on here will take them seriously
20th Dec 2018 3:07pm |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 520 |
Agreed there 100%, we are driving a Land Rover - upgrading to Wipacs and Nightbreakers is more than ample - spending £hundreds on LED’ s is totally pointless, gain virtually nothing and look awful like a cheap biscuit tin out of a Darth Vader movie. |
20th Dec 2018 11:26pm |
Mother superior Member Since: 05 Aug 2013 Location: Surrey Posts: 504 |
Gents
I went down the HID route, quite happy with them as they match my LED side lights pretty well and give a good output. I got mine from HIDS4U over on the D3 forum Oh woe, oh woe My crusty old landrover, It will not go. |
22nd Dec 2018 7:30pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17374 |
^^^ How did you make them legal?
22nd Dec 2018 8:06pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8581 |
Do not be tempted to fit a HID conversion kit into a headlight designed for halogen filament bulb as it is illegal. Taken from the Hids4u website
So they are admitting that their kits are illegal why else taken them out for a MOT? Taken from the MOT testers manual section 4.1.4 [url=https://www.mot-testing.service.gov.uk/documents/manuals/class3457/Section-4-Lamps-reflectors-and-electrical-equipment.html#section_4.1]here[url]
Now the UK Vehicle Lighting Regulations clearly state that headlights must carry an approval mark. Part of the approval mark is the light function code Class CR or C/R are tungsten filament lamps HCR or HC/R is normally LED DR or DCR is normally HID Fit a different light source in a headlamp and approval mark is void Also a MOT major defect Taken from the MOT testers manual
The ONLY legal way to change the type of light source in a headlamp is to replace the whole unit for one which has the correct genuine approval markings on. Brendan |
22nd Dec 2018 8:24pm |
Jas Ardis Member Since: 28 Jun 2018 Location: Salisbury Posts: 56 |
In terms of cost effectiveness they’re way down there with lights that are cheap and rubbish. I think some folk are laughing their way to the bank. A grand? Really? Let’s put that in the tank and go some place we’ve never been. Even if it’s at circa 20 mpg. |
2nd Aug 2019 8:05pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2152 |
Have always used PIAA bulbs in other vehicles and in approx 15+yrs have only ever had 1 bulb fail.......
2nd Aug 2019 8:21pm |
Banbury Member Since: 22 Jan 2019 Location: Oxfordshire Posts: 47 |
Yep. I have those JW Speaker LEDs with the heat function (“SmartHeat® Headlights - JW Speaker Dual Burn (DRL)”. How can I say this - they are awfully bright - but are installed not to dazzle. The engineers who fitted them made sure they were setup correctly. Great at night and the DRLs look quite fetching in the day.😊 |
3rd Aug 2019 8:57pm |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 916 |
Over the years I have tried many a different types just to get the most light on the road as street lights are a uncommon sight out here in the sticks. From the days of using relays and Ring Rally sport 130 watt bulbs, to being legal and using the crystals and the GE megalight bulbs, I relented and went Trucklite after a headlight relay burned out.
Even though some might argue that the trucklite isn't the brightest HL The overall experience is far beyound what the older fillament bulbs could produce, Nice colour light with good spread, not to mention a sealed unit that won't let water in when wading. I have written off a few bulbs with sub aqua endevours. A family member ran crytals and a retro fit HID kit and all it gives a Dazzaling puddle of light with no aim or discernable beam pattern. yes it was bright but in the rear view or heading towards him it was dangerous and unsafe. LED are a expensive upgrade granted but I feel the benefits work well. Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
4th Aug 2019 10:26am |
That's not surprising . Retro fit HID kits are illegal for exactly that reason. Darren
4th Aug 2019 10:54am |
stooopid question time but looking at the front it appears you have to remove the lamp assembly to change the bulbs???
is that right or am i missing something?? |
5th Aug 2019 11:51am |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
Your correct 90 Dreamer 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
5th Aug 2019 11:57am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
So I have been on a route of Wipac Crystal with +130% Osram nightbreaker.
Now have Trucklite LED with the uprated Land Reizger loom. In honesty, i think the nightbreakers with Wipac Crystal plus loom upgrade are as good as anything. My LED's seem to be better in some ciscumstances, but less good in others. Terrible in falling snow for instance, the LED causes a lot of reflected glare. In hindsight nightbreakers with Wipac Crystal plus loom upgrade are as good as anything. One benefit of the LED's I have is they don;t need masking for overseas use, the cut-off is flat. Plus they have bright sidelights - almost of DRL quality Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
5th Aug 2019 12:28pm |
cheers, is it the whole lamp surround or just the lamp lens?? |
5th Aug 2019 1:53pm |
