Home > Puma (Tdci) > Was BBus standard?
WindyJ
Was BBus standard?
I was under the impression all SW versions of puma engined defenders had BBUS fitted behind the headlight. Mine shows no sign of there ever being anything in there. Can I probably was a bit quick in ordering the relocation loom without checking first! Cant see it located anywhere else. Is there a way to check easy ?
Post #745484 13th Dec 2018 11:28am
dorsetsmith
2.4 or 2.2 engine Question
Post #745485 13th Dec 2018 11:37am
blimbug
United Kingdom 2009 Defender 110 Puma 2.4 SW Bonatti Grey
Sounds like a similar situation to myself - should have checked before I ordered!
Mine is a 2009 XS station wagon and I can't find it, so i'm guessing it wasn't a standard option?
Post #745486 13th Dec 2018 11:39am
dorsetsmith
Not all 07 to 2011 Puma TDCi defender have wire and plug in place in the wing loom
check C1264 plug if you only have one black wire concreted in the plug you will not have the brown BBUS plug at head light end. If you have 4 black wire concreted in the plug you will brown BBUS plug at head light end. all is not lost if your loom is missing wiring and brown plug
Post #745488 13th Dec 2018 11:53am
kmac
BBUS was only standard from MY 11 onwards
Post #745503 13th Dec 2018 1:41pm
It's not behind either headlight on my 2013 model. I know it has one fitted as I've inadvertently set it off, but I'm dammed if I can find it (which is a good thing).
Perhaps LR installed them differently on later vehicles? Darren
Post #745504 13th Dec 2018 1:52pm
WindyJ
late 2008 2.4
Post #745505 13th Dec 2018 1:57pm
dorsetsmith
late 2008 2.4 ok
Post #745524 13th Dec 2018 3:37pm
WindyJ
Thanks for this, i’ll take a look tomorrow. Its always possible the previous owner relocated it already....
Post #745590 13th Dec 2018 7:35pm
Td5s have the harness with the plug. If your TDCi doesn't, you can pick up a Td5 harness from a breaker.
Post #745600 13th Dec 2018 8:12pm
dorsetsmith
or just add wiring and plug
Post #745612 13th Dec 2018 8:49pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
Never fitted on export models. My 2015 doesn't even have an alarm. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #745786 15th Dec 2018 9:51am
Roger
United Kingdom 2007 Defender 110 Puma 2.4 SW Java Black
WindyJ, I did the exact same when I bought a BBUS relocation loom! Laughing The advantage was, after I found my wiring harness did not include a BBUS connector, and after I actually got a BBUS(!), I just added the pins to the relocation loom and plumbed it straight into the C1264 connector.
Took a bit of mining to find the relevant info as naturally most folk aren't too keen to share security system info.
Post #746429 19th Dec 2018 3:03pm
