Home > Puma (Tdci) > Was BBus standard? |
2.4 or 2.2 engine
13th Dec 2018 11:37am |
blimbug Member Since: 17 Mar 2016 Location: Wiltshire Posts: 92 |
Sounds like a similar situation to myself - should have checked before I ordered!
Mine is a 2009 XS station wagon and I can't find it, so i'm guessing it wasn't a standard option? |
13th Dec 2018 11:39am |
Not all 07 to 2011 Puma TDCi defender have wire and plug in place in the wing loom
Click image to enlarge check C1264 plug if you only have one black wire concreted in the plug you will not have the brown BBUS plug at head light end. If you have 4 black wire concreted in the plug you will brown BBUS plug at head light end. all is not lost if your loom is missing wiring and brown plug Click image to enlarge Click image to enlarge |
13th Dec 2018 11:53am |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
BBUS was only standard from MY 11 onwards
13th Dec 2018 1:41pm |
It's not behind either headlight on my 2013 model. I know it has one fitted as I've inadvertently set it off, but I'm dammed if I can find it (which is a good thing).
Perhaps LR installed them differently on later vehicles? Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
13th Dec 2018 1:52pm |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 |
late 2008 2.4 |
13th Dec 2018 1:57pm |
late 2008 2.4 ok
13th Dec 2018 3:37pm |
Thanks for this, i’ll take a look tomorrow. Its always possible the previous owner relocated it already.... |
13th Dec 2018 7:35pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17378 |
Td5s have the harness with the plug. If your TDCi doesn't, you can pick up a Td5 harness from a breaker.
13th Dec 2018 8:12pm |
or just add wiring and plug
13th Dec 2018 8:49pm |
BogMonster Member Since: 05 Feb 2008 Location: Stanley Posts: 400 |
Never fitted on export models. My 2015 doesn't even have an alarm. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi |
15th Dec 2018 9:51am |
Roger Member Since: 26 Apr 2018 Location: Hampshire Posts: 71 |
WindyJ, I did the exact same when I bought a BBUS relocation loom! The advantage was, after I found my wiring harness did not include a BBUS connector, and after I actually got a BBUS(!), I just added the pins to the relocation loom and plumbed it straight into the C1264 connector.
Took a bit of mining to find the relevant info as naturally most folk aren't too keen to share security system info. |
19th Dec 2018 3:03pm |
