Home > Technical > Swapping rear panels.
landy andy
I’ve now got a pair of utility side panels painted, new seals, and am ready to fit them.
Anybody else done this?
Any advice?
I’ve been told that I do not have to remove the complete roof to fit panels, but what do I have to do? I know back door hinge has to come off, trim around the rear windows, and part of the ceiling lining. But how much of the lining?
Thanks in advance
Andy.
Post #736211 22nd Oct 2018 6:15pm
landy andy
Wow. Looks like I will be the first to do this then.
Post #736378 23rd Oct 2018 6:14pm
It can be done by unbolting the roof from the sides and then easing the roof up enough to swap the panels over. Prop the roof with some timber - it only needs to be lifted a couple of inches. You'll have to take out enough of the roof to give access to the bolts, which will be at least the rear and centre sections. Darren
Post #736385 23rd Oct 2018 6:36pm
landy andy
Thank you. Fixings for ceiling are reusable or should I buy new for refitment.
Andy.
Post #736386 23rd Oct 2018 6:39pm
You should be able to reuse them if you take them out carefully. I've had the lining out of mine twice and reused the fixings without issue. Darren
Post #736387 23rd Oct 2018 6:41pm
donmacn
Fixings are reusable - just nuts and bolts.
I did almost the same thing last week (some pics on my 'tinkering' thread - in my sig below). I wasn't replacing roof panels though, just adjusting them, but it's effectively the same thing. You might need to get your roof a little higher to be able to clear the corner fixings in the tub.
Good luck! Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #736389 23rd Oct 2018 6:46pm
Merlin
This is a pdf that was sent to me from Bearmach. It is for a 110. Sit down when you get to the prices!
https://www.defender2.net/gallery/albums/u...armach.pdf
Peter
Post #736397 23rd Oct 2018 7:01pm
landy andy
Thanks. I’ve got the panels, and had them sprayed for me.
Post #736413 23rd Oct 2018 8:12pm
landy andy
Here we go then.
Should have bought new fir fixings for ceiling lining though. Everyone apart from two snapped. I’m sure I would have had more success if it was above 3degrees C today Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Twisted Evil
Andy.
Post #737025 27th Oct 2018 11:15am
landy andy
That’s better
Post #737037 27th Oct 2018 12:34pm
landy andy
All done and I’m much happier with it.
Post #737055 27th Oct 2018 3:26pm
rustandoil
Looking great Thumbs Up
Post #737057 27th Oct 2018 3:29pm
Looks very smart Thumbs Up Darren
Post #737104 27th Oct 2018 7:08pm
Zed
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
Very nice work.
Post #737108 27th Oct 2018 7:23pm
landy andy
Thanks I’m very pleased with how it looks.
Got to clean the CSW rear panels up, and get them listed for sales to get some of the outlay back now.
Andy
Post #737152 28th Oct 2018 8:53am
