![]() | Home > Tdi > New Fuel Tank - Help |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 ![]() ![]() ![]() |
Are you sure the breather pipe is not blocked or trapped?
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 ![]() ![]() |
Yeh it seems fine, I’ve had a few responses on some FB pages so going to check the fuel pick up line in the morning to see if there’s some sort of obstruction
![]() 2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5812 ![]() ![]() |
Test drive it with the filler cap off.
Are you sure flow and return pipes are the correct way around? |
Well, it turned out to be the fuel lift pump, I could’ve sworn that was fine so just goes to show. All back to normal now
