Home > Tdi > New Fuel Tank - Help
StephenO
Hi,
I’ve fitted a new fuel tank to my 90 due to my old one leaking. After fitting I’ve been having issues, struggling to get up hills, no power, feeling like it’s about to stall then after a while it does. Does start again but then the same all over again.
Since then I’ve changed the filter, manually pumped fuel through and took it for a run, seemed better. Took it for a test drive today and the same all over again. I checked the new filter and there was no fuel in it so attempted to pump fuel through again but nothing.
I’ve ordered a new fuel lift pump, should be here Monday but there wasn’t an issue with the pump prior to the tank change.
Can you suggest anything else, am I missing something?
Stephen 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey
1968 Series 2a Bronze Green
1995 Defender 90 Coniston Green
2005 Discovery 3 Zambezi Silver
Post #735573 18th Oct 2018 5:57pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Are you sure the breather pipe is not blocked or trapped?
Post #735594 18th Oct 2018 7:00pm
StephenO
Yeh it seems fine, I’ve had a few responses on some FB pages so going to check the fuel pick up line in the morning to see if there’s some sort of obstruction Thumbs Up 2007 Defender Puma Tonga Green
Post #735596 18th Oct 2018 7:05pm
landy andy
Test drive it with the filler cap off.
Are you sure flow and return pipes are the correct way around?
Post #735620 18th Oct 2018 8:16pm
StephenO
Well, it turned out to be the fuel lift pump, I could’ve sworn that was fine so just goes to show. All back to normal now Thumbs Up 2007 Defender Puma Tonga Green
Post #736243 22nd Oct 2018 7:43pm
