Home > Tdi > New Fuel Tank - Help |
Scoobeenut Member Since: 04 Mar 2015 Location: West London Posts: 310 |
Are you sure the breather pipe is not blocked or trapped?
18th Oct 2018 7:00pm |
StephenO Member Since: 03 Dec 2010 Location: Glasgow Posts: 246 |
Yeh it seems fine, I’ve had a few responses on some FB pages so going to check the fuel pick up line in the morning to see if there’s some sort of obstruction 2007 Defender Puma Tonga Green
2015 Range Rover Sport Autobiography Corrie Grey 1968 Series 2a Bronze Green 1995 Defender 90 Coniston Green 2005 Discovery 3 Zambezi Silver |
18th Oct 2018 7:05pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Test drive it with the filler cap off.
Are you sure flow and return pipes are the correct way around? |
18th Oct 2018 8:16pm |
Well, it turned out to be the fuel lift pump, I could’ve sworn that was fine so just goes to show. All back to normal now 2007 Defender Puma Tonga Green
22nd Oct 2018 7:43pm |
