Home > In Car Electronics > 5 pin carling switch wiring diagram
Page 1 of 3 123>
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
Can anyone confirm the correct 5 pin connections for these on - off switches please?
Wiring in some LED aux lights via a fused power supply.
been on internet and the Mudstuff site (supplier) gives one option but the switches dont have a connector number 1
Which pin is :-
Power in (12.2v tested)
Power out to lights
dash lights
Earth switch
Earth to lights
Cant understand how something so simple is doing my head in
Advice appreciated 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #735246 17th Oct 2018 9:31am
Martin
Site Admin
Which exact switch & spec is it?
Earth to the lights will be done direct, not via the switch. The switch only switches the 12V power.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #735249 17th Oct 2018 9:48am
JOHNT01670
The switches are carling V-rocker (off-on) with 5 connectors at the back. 2006 TD5
Post #735252 17th Oct 2018 10:13am
rallysteve
Get the datasheet from the Carling website and you will be able to work it out quite easily by using the part number which should be stamped into the top of the switch.
If it is an on/off switch though, the two terminals which are at the top of the switch body are the illumination (LED so polarity dependant) and the three terminals which are in the centre will be the switch contacts. It will probably be on/on actually so the centre contact of the three will be your supply and on of the other two will be your switched output dependant on whether you want the switch to function in the up or down position.
If the switch has the tell-tale this will probably not work correctly if you sourced the switch from Mud-stuff as it will be a US spec switch with on being the uppermost position. If this is the case you will need to connect differently (personally i think this is a bodge) for the telltale to work correctly.
If you purchased it from mobilecentre it will function correctly without the bodge,
Post #735255 17th Oct 2018 10:31am
landy andy
I’m assuming
Live in
Switch live
Illumination
Switch on light
Negative (required to operate illumination)
Post #735256 17th Oct 2018 10:31am
Martin
Site Admin
The reason I ask which exact switch you ordered is that there are many variations, including US and EU type.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #735259 17th Oct 2018 10:38am
JOHNT01670
single throw ON - OFF switch
Single Pole Single Throw ON - OFF switch
Dual LED lights in GREEN
Upper light is ON when the switch is pressed UP.
Lower light can be wired to separate dash light circuit.
Same size as the ARB switches.
Waterproof rating of IP66.
Rated 20A 12V / 10A 24V.
This switch uses the same light configuration as the ARB switches.
 2006 TD5
Post #735260 17th Oct 2018 10:42am
landy andy
Google shows
Post #735262 17th Oct 2018 10:48am
JOHNT01670
Thanks gents - gonna investigate further this afternoon..... think earthing is the root cause of my issues 2006 TD5
Post #735264 17th Oct 2018 10:49am
Martin
Site Admin
Your pinout doesn't seem to be on Mud's PDF list, I would expect Mud to supply a pinout for it.
However your description doesn't seem to be from Mud's site either.
Confused! Confused Laughing  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #735267 17th Oct 2018 11:11am
Martin
Site Admin
Is it a genuine Carling or a clone? The 5 pin with that layout (no pin 1) seem to be clones Confused  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #735269 17th Oct 2018 11:16am
JOHNT01670
All sorted, I had an issue with the lights earth and wired the switches up as per the diagram provided by Andy above.
I have a mix of switches the ones I am currently using are not from MUD (some of the others are) but were purchased as Carlings (described as Carling ARB type switches) hence the confusion.
Problem solved - thanks for the input folks which helped greatly
John 2006 TD5
Post #735488 18th Oct 2018 8:37am
landy andy
Thumbs Up
Post #735491 18th Oct 2018 8:42am
Martin
Site Admin
"Type" indicates they are clones hence the lack of useful info on them on Mud's site Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #735497 18th Oct 2018 9:39am
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
have two types
Some with pins like this
8 7
2
3 6
And some like this
8. 7
1
2
3
The top ones I have the wiring down as 8 and 7 earth, 2 as live feed 3 to relay 6 light circuit
The problem I have is the second ones.... I can find a pin list that makes sense....
Your help would be much appreciated @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #740715 15th Nov 2018 6:45pm
Page 1 of 3 123>
