Home > In Car Electronics > 5 pin carling switch wiring diagram
Page 2 of 3 <123>
Martin
Site Admin
What spec of switch are the second ones?
Off/On or On/On? Normal or momentary?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #740720 15th Nov 2018 7:38pm
leeds
Which make of switches have you got Steve?
The switch with terminal layout below is not on the Carling switch layout on the Mud site
8 . 7
2
3 . 6
So which brand of switch is it?
Switches with terminal lay out
8 . 7
1
2
3
Couldbe a few different switches
Try rocking the switch. Does it lock into a position when pressure is removed or is it sprung loaded to return to centre
If a Carling switch it could be
a) . Off-On (EU)
b) . On-On (EU & USA)
c) . Mom-off-Mom (EU & USA)
c) can be determined if the switch does not latch into the top or bottom position and rests in middle.
b) . Put a meter on pin 2 and 1 and rock the switch should get zero resistance on either the top or bottom position. Meter on 2 and 3 should get zero resistance in opposite switch position. This switch will lock into top and bottom and rest in middle
a) Off-ON . (EU) . Meter on 2 and 1 should get zero resistance. Should lock into either top or bottom . off-on
HTH
Brendan
Post #740722 15th Nov 2018 7:44pm
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Second switches are off on.... @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #740724 15th Nov 2018 7:54pm
Steve_overland
The first are from a company called on board air... so I’m guessing at not genuine .... @steve_overland on Insta.
Post #740725 15th Nov 2018 7:55pm
Martin
Site Admin
https://www.mudstuff.co.uk/pdfs/Carling%20...202017.pdf
Gives
1: Power In
2: Power Out
3: Link to Pin 2
7: Earth
8: Illumination+
Your first switch appears to be a "Carling type"/clone as we discussed above. Follow landy andy's posted image.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #740726 15th Nov 2018 7:56pm
Steve_overland
Cheers Martin...
What does the link to pin 2 do ??? @steve_overland on Insta.
Post #740727 15th Nov 2018 8:00pm
rallysteve
Its a bodge to make the indicator lamp in the switch work because the mudstuff ones are US spec. 02' 110 TD5 Double Cab Rebuild Thread
Post #740729 15th Nov 2018 8:01pm
Martin
Site Admin
@Steve_Overland: have you got the Carling part code from the body of the switch?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #740730 15th Nov 2018 8:04pm
Steve_overland
1829 r @steve_overland on Insta.
Post #740731 15th Nov 2018 8:05pm
Martin
Site Admin
Hmmm. Should be a code starting V1D?
Answer to your previous question is: I don't know what the link to pin 2 does - it doesn't match the expected working from Carling's own datasheet.
Hence asking what the exact Carling switch code is so I can find it Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #740732 15th Nov 2018 8:09pm
Steve_overland
V4d2 maybe @steve_overland on Insta.
Post #740733 15th Nov 2018 8:11pm
Martin
Site Admin
Ok V4 are On-On type
Power in to 2
Power out to 1 in one position
Power out to 3 in the other
No link required.
Check with a meter which of 1 or 3 is connected to 2 with the switch in your desired "on" position.
The US/EU types available make this a headache too.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #740735 15th Nov 2018 8:21pm
Steve_overland
Is that still the earth and illumination as before...7 earth 8 from lights... 2 power in and then 1 or 3 power out.... @steve_overland on Insta.
Post #740739 15th Nov 2018 8:26pm
Martin
Site Admin
Yep  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #740740 15th Nov 2018 8:26pm
Steve_overland
Legend thank you so much..... @steve_overland on Insta.
Post #740741 15th Nov 2018 8:27pm
Page 2 of 3 <123>
