![]() | Home > In Car Electronics > 5 pin carling switch wiring diagram |
JOHNT01670 Member Since: 24 Jun 2015 Location: CRAMLINGTON, Northumberland Posts: 190 ![]() ![]() ![]() |
Can anyone confirm the correct 5 pin connections for these on - off switches please?
Wiring in some LED aux lights via a fused power supply. been on internet and the Mudstuff site (supplier) gives one option but the switches dont have a connector number 1 Which pin is :- Power in (12.2v tested) Power out to lights dash lights Earth switch Earth to lights Cant understand how something so simple is doing my head in Advice appreciated 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Which exact switch & spec is it?
Earth to the lights will be done direct, not via the switch. The switch only switches the 12V power. ![]() ![]() |
The switches are carling V-rocker (off-on) with 5 connectors at the back. 2006 TD5
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Get the datasheet from the Carling website and you will be able to work it out quite easily by using the part number which should be stamped into the top of the switch.
If it is an on/off switch though, the two terminals which are at the top of the switch body are the illumination (LED so polarity dependant) and the three terminals which are in the centre will be the switch contacts. It will probably be on/on actually so the centre contact of the three will be your supply and on of the other two will be your switched output dependant on whether you want the switch to function in the up or down position. If the switch has the tell-tale this will probably not work correctly if you sourced the switch from Mud-stuff as it will be a US spec switch with on being the uppermost position. If this is the case you will need to connect differently (personally i think this is a bodge) for the telltale to work correctly. If you purchased it from mobilecentre it will function correctly without the bodge, Steve 02' 110 TD5 Double Cab Rebuild Thread |
The reason I ask which exact switch you ordered is that there are many variations, including US and EU type.
single throw ON - OFF switch
Single Pole Single Throw ON - OFF switch Dual LED lights in GREEN Upper light is ON when the switch is pressed UP. Lower light can be wired to separate dash light circuit. Same size as the ARB switches. Waterproof rating of IP66. Rated 20A 12V / 10A 24V. This switch uses the same light configuration as the ARB switches. ![]() 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5811 ![]() ![]() |
![]() Click image to enlarge Google shows |
Thanks gents - gonna investigate further this afternoon..... think earthing is the root cause of my issues 2006 TD5
Your pinout doesn't seem to be on Mud's PDF list, I would expect Mud to supply a pinout for it.
However your description doesn't seem to be from Mud's site either. Confused! ![]() ![]() ![]() ![]() |
Is it a genuine Carling or a clone? The 5 pin with that layout (no pin 1) seem to be clones
All sorted, I had an issue with the lights earth and wired the switches up as per the diagram provided by Andy above.
I have a mix of switches the ones I am currently using are not from MUD (some of the others are) but were purchased as Carlings (described as Carling ARB type switches) hence the confusion. Problem solved - thanks for the input folks which helped greatly Cheers John 2006 TD5 2002 Honda Transalp 650 1995 Yamaha Vmax 1200 2014 Nissan Juke (wifes) |
"Type" indicates they are clones hence the lack of useful info on them on Mud's site
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 ![]() ![]() ![]() |
have two types
Some with pins like this 8 7 2 3 6 And some like this 8. 7 1 2 3 The top ones I have the wiring down as 8 and 7 earth, 2 as live feed 3 to relay 6 light circuit The problem I have is the second ones.... I can find a pin list that makes sense.... Your help would be much appreciated @steve_overland on Insta. 110 expedition vehicle with pop roof |
