Home > Puma (Tdci) > Output shaft failure, Forum Survey
Page 22 of 33 <123 ... 212223 ... 313233>
No, no at all. Apart from the fact that the presence of oil would prevent corrosion and debris forming in the first place, there's no mechanism that would draw the oil back into the 'box. Darren
Post #936242 4th Jan 2022 8:47am
Caterham
Thumbs Up
not sure I agree with the first part of your response tho Question
if no corrosion etc would that not assume the shaft - hasn/t / wouldn't fail?
Confused
Post #936255 4th Jan 2022 10:00am
Not necessarily. From what I've seen corrosion is merely a consequence of lack of lubrication and not in itself the prime cause of failure. There are several reasons why failure can occur including poor installation, although the prime suspect seems to be some sort of misalignment. Darren
Post #936261 4th Jan 2022 10:26am
Caterham
Thumbs Up
personally if I had the time I'd be looking into the possibilities of removing the mt82 + adapter shaft and replace with the tremec t56 magnum. It's longer and hopefully long enough to do away with the adapter altogether. connecting this to the lt230 has been done many times it just the clutch end / bell housing?
granted it wouldn't be cheap but resale on the gearbox and not having to pay for a replacement shaft every so often / reliability would for me be worth several thousand pounds? hmm
Post #936265 4th Jan 2022 10:56am
Caterham
thinking about it.
as said elsewhere;
the mt82 is well proven,
the lt230 is well proven,
the method of connecting the two ie an adapter shaft is a well proven principle.
therefore the only possible problem is the adapter shaft housing. surely there are people out there that could both verify this and build a replacement housing to the necessary tolerances?
isn't this a preferential route to take over the ashcroft adapter and the one piece offerings out there?
granted such a thing is not currently available and hence the above options are preferrable. Confused
Post #936267 4th Jan 2022 11:01am
I suspect that you're right but imagine that an adapter housing is much more complicated to manufacture than a revised shaft. As the latter seems to solve the problem in the majority of vehicles that suffer, it's also a very limited market. I appreciate that's no comfort for those with a vehicle that eats shafts more regularly, though.
If you do have such a vehicle then I guess it'd be worth finding somebody that could properly investigate the 'box alignment and undertake the necessary machining to cure it. Doesn't sound cheap though, unfortunately. Darren
Post #936272 4th Jan 2022 11:14am
I know this has all been said before, but it perhaps worth restating. The immediate cause of failure is a process known as fretting, i.e., the gradual erosion of the parts as a result of rubbing. For failure to occur there must be a continuous repetitive movement within the joint.
There are several factors which will determine how fast this occurs, namely:
    a) the extent of rubbing which is taking place,
    b) the contact surface area over which is it happening,
    c) the presence or absence of lubrication
    d) the presence or absence of other contaminants which may form an additional abrasive medium within the joint.
Item (a) ​will primarily be down to the alignment of the parts, and will depend on how parallel the rear of the gearbox is with the front face of the transfer box and how accurate is the axial alignment of the gearbox mainshaft with the transfer box input gear (and I suspect that this is the most significant variable).
Item (b) will primarily come into play as the coupling starts to fail and the surfaces wear, but there is also evidence of the two parts coming apart in many failures (i.e., the spring ring fails to retain the male part in the female part), which may be as a result of incorrect assembly, or may be the result of the parts simply separating as a result of (a) and a lack of lubrication. As soon as separation begins the contact forces will be massively increased and any wear will accelerate in proportion to the reduction in contact area.
Item (c) is largely self-explanatory, but it should be noted that a coupling of this type should never be assembled without suitable lubrication and that fact that Landrover evidently did so for a long time or over many discrete periods is simply appalling (sadly not unexpected though). Unless a continuous oil feed can bee provided (as in the Ashcroft modification) the lubricant must be a suitable grease (Molybdenum Disulphide being probably the most suitable), but it should be remembered that all greases dry out over time and grease will tend to be ejected from the places where it is needed, and therefore periodic re-greasing will be necessary. With the right grease this can probably be done as infrequently as the clutch is replaced. Lubrication will not prevent wear from occurring if there is movement, however it may well slow the rate of wear to the point where it ceases to be a problem.
Item (d) will mainly be the result of a failure to lubricate, with the result that rust can form and, in the absence of lubrication, form an abrasive paste or powder within the joint. Once again there are many examples of this happening.
There is ample evidence to support the above, for example there are vehicles with high mileages on their original shafts (my own had no evidence of lubrication at all when I first took it apart at 150k miles, and since being lubricated then it has now done well over 250k miles in total. This can only have happened if I have parts which result in near perfect alignment), yet there are vehicles such as Keith's which have good lubrication and still fail at low mileages.
I believe that ultimately there can be no doubt that this joint will fail eventually if there is any significant misalignment in the gearboxes. Correct assembly and suitable lubrication will postpone this, but only correct alignment will prevent it.
Post #936274 4th Jan 2022 11:21am
Caterham wrote:
thinking about it.
as said elsewhere;
I tend to agree with you, and supporting evidence includes that fact that I have changed my transfer box and doing so does not appear to have affected the longevity of my coupling (which as I tend to repeat with boring regularity has now done more than 250k miles).
It should be noted however that the housing is a very tricky shape to measure accurately. Although checking the front and rear faces for parallelism is easy enough, if the dowel holes in either face are machined inaccurately it would be incredibly difficult to tell but would result in the two ends of the shaft not being aligned axially. I suspect that this is what is happening.
Since only Landrover and the manufacturer of the part, who was, presumably, supplied with the a CAD file or drawings including tolerances, know where the dowel holes should be, it is hard to check. Measurements would have to be accurate in two axes, of course.
It would be possible to carry out comparative measurements between a known good part and a known coupling-eater, if one had access to them, but even this would require access to some fairly fancy equipment. If I had the time it is something I would be fascinated to delve into, I would love to be able to prove my theory. I probably have the equipment to do it, but not the time to dismantle my transmission, make some tooling, and take the measurements, and I don't have a known bad adaptor housing for comparison.
Post #936278 4th Jan 2022 11:37am
MK
I believe the rate of failure of the ashcroft kit so far =0. Disregarding some oil leak problems in the early models. Puma 110" SW
Post #936280 4th Jan 2022 11:49am
Unfortunately that's no longer the case. See Keith's post towards the end of page 20. Darren
Post #936281 4th Jan 2022 11:55am
MK
OK but I believe we have not seen the shaft etc yet (?) Not sure Puma 110" SW
Post #936283 4th Jan 2022 11:59am
Caterham
hi BW and a very happy new year to you.
just a thought - and again I'm not suggesting this is going to be easy.....
could a rig not be made up on a good set up ie yours - remind me how many adapter shafts have you got through and at what mileage Mr. Green
could a rig mounted on the gearbox externals locate the position of the lt230. I appreciate this might not be as accurate as it should be but presumably close enough to establish if a 'bad one' isn't in the same position?
Post #936284 4th Jan 2022 12:05pm
Caterham
just another thought on this?
is it possible its a simple case of the shaft isn't balanced?
especially bearing in mind it has that plastic cover on it.
I know prop shafts have to be balanced - I appreciate they are a lot heavier and far more likely to be out of balance - just a thought?
Post #936286 4th Jan 2022 12:10pm
jpboost
United Kingdom 2014 Defender 110 Puma 2.2 SW Keswick Green
I think the nature of the failures would suggest it wasn't the quality (balancing or otherwise) of the actual shafts.
As others have said above (and probably clearer than i am), if some cars get through multiple shafts in relatively short mileages, but others are fine for huge mileage, you can discount variance in the shafts themselves. The difference has to be something relating to the vehicles we're fitting them into.
Post #936290 4th Jan 2022 12:33pm
Bluest
Something I would do if I had a car that was chomping through shafts quickly is replace the adapter housing with another used one from a breakers, higher mileage the better. This is on the basis that the replacement should be better, and if it is not it is unlikely to be worse. 2007 110 TDCi Station Wagon XS
Post #936291 4th Jan 2022 12:34pm
