Home > Td5 > Straight Through Exhaust
Greeny
I have been told that you need some back pressure from a silencer for the engine. With a 1999 TD5 it does not have a CAT. If I was to completely straight pipe the exhaust, no small rear silencer etc, would I need to have a smaller silencer on it to build up some back pressure? After going in a TD5 with no rear silencer it sounded amazing, but they told me it had a small silencer where the CAT is to keep some back pressure. So if I dont have a CAT do I need some sort of silencer to keep the engine running nicely or can I just remove my rear silencer so it is fully straight piped?
Thanks. Instagram - @Land_Rover_Defender
Post #713378 20th Jun 2018 7:26am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
The rear silencer doesn't give much back pressure and I only run the rear silencer. No problems. I don't think a turbo diesel needs any back pressure.
http://www.youtube.com/watch?v=JtvkRCuHmKM Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #713388 20th Jun 2018 8:13am
Greeny
Thanks,
At the moment the exhaust has the middle box removed and replaced with a straight pipe and I am running a small silencer on the rear. Because it is a 1999 TD5 it does not have a CAT. I have been told that you need some back pressure, and I was thinking that if I removed the rear silencer it wouldn't have any at all. Instagram - @Land_Rover_Defender
Post #713394 20th Jun 2018 8:26am
Clive
I'm not so sure that a TD "needs" back pressure but in any case the turbo itself will create some, my understanding is that the less constriction there is after the turbo the more responsive it will be by spooling up more quickly.
Post #713431 20th Jun 2018 11:41am
Greeny
So you think that running a full straight pipe will be fine? Original downpipe and then straight through after that. Instagram - @Land_Rover_Defender
Post #713445 20th Jun 2018 1:45pm
bankz5152
Diesels dont need back pressure. Fit one Instagram @defender_ventures
Empire Tuning - Agent
Post #713510 20th Jun 2018 6:39pm
Greeny
Thanks for the replies guys! Instagram - @Land_Rover_Defender
Post #713600 21st Jun 2018 7:10am
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Keep the last rear small silencer or it makes it to raspy and annoying 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #713632 21st Jun 2018 9:08am
Greeny
I dont mind it being raspy. I dont drive long distances so I want it to be loud when I do drive it. Instagram - @Land_Rover_Defender
Post #713633 21st Jun 2018 9:11am
Pilgrimmick
Seems a bit anti social just being loud for the sake of it! 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #713671 21st Jun 2018 1:28pm
5 POT
United Kingdom 2005 Defender 110 Td5 SW Java Black
I kept the front silencer in the front pipe and straight through from there - sounds amazing! It isn't anti social until you want it to be. You need to get your exhaust gases away as quickly as possible so better to have less silencers nearer the rear.
I have a mate who went straight through without any silencers inc the front and his kept going into limp mode because of the over boost (remap and intercooler as well) so he fitted a boost box and all was fine.
I would keep your front pipe as is and just swap the rear pipe out for a non silenced section
Post #713851 22nd Jun 2018 10:49am
BLACK LAB
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
That sounds pretty good . 2006 DEFENDER 90 TD5 CSW XS
2018 RANGE ROVER SPORT HSE DYNAMIC
Post #713906 22nd Jun 2018 5:48pm
pj2106
5 pot do you mean the manifold down pipe? As in the cat you left on or the middle section? 2008 110 2.4 XS Utility (Hagrid)
Post #713950 22nd Jun 2018 10:06pm
Lancerdoc999
How does this affect the new MOT rules. I have removed my mid and rear and need to replace with something, just not sure what at the moment.
Post #714186 24th Jun 2018 2:32pm
Greeny
My front pipe is standard yes. But it doesnt have a silencer in it? Because its 1999 it doesnt have a CAT so is just straight down from the manifold. Instagram - @Land_Rover_Defender
Post #714232 24th Jun 2018 7:11pm
