![]() | Home > Td5 > Straight Through Exhaust |
The rear silencer doesn't give much back pressure and I only run the rear silencer. No problems. I don't think a turbo diesel needs any back pressure.
http://www.youtube.com/watch?v=JtvkRCuHmKM Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
Greeny Member Since: 20 Mar 2018 Location: Buckinghamshire Posts: 272 ![]() ![]() |
Thanks,
At the moment the exhaust has the middle box removed and replaced with a straight pipe and I am running a small silencer on the rear. Because it is a 1999 TD5 it does not have a CAT. I have been told that you need some back pressure, and I was thinking that if I removed the rear silencer it wouldn't have any at all. Instagram - @Land_Rover_Defender |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I'm not so sure that a TD "needs" back pressure but in any case the turbo itself will create some, my understanding is that the less constriction there is after the turbo the more responsive it will be by spooling up more quickly.
So you think that running a full straight pipe will be fine? Original downpipe and then straight through after that. Instagram - @Land_Rover_Defender
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2192 ![]() ![]() |
Diesels dont need back pressure. Fit one Instagram @defender_ventures
Empire Tuning - Agent |
Thanks for the replies guys! Instagram - @Land_Rover_Defender
pj2106 Member Since: 20 Dec 2012 Location: Huntingdon AKA The Shire Posts: 1500 ![]() ![]() ![]() |
Keep the last rear small silencer or it makes it to raspy and annoying 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold 1998 300TDi D1 (Billy) Sold |
I dont mind it being raspy. I dont drive long distances so I want it to be loud when I do drive it. Instagram - @Land_Rover_Defender
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
Seems a bit anti social just being loud for the sake of it! 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
5 POT Member Since: 24 Nov 2014 Location: UK Posts: 81 ![]() ![]() ![]() |
I kept the front silencer in the front pipe and straight through from there - sounds amazing! It isn't anti social until you want it to be. You need to get your exhaust gases away as quickly as possible so better to have less silencers nearer the rear.
I have a mate who went straight through without any silencers inc the front and his kept going into limp mode because of the over boost (remap and intercooler as well) so he fitted a boost box and all was fine. I would keep your front pipe as is and just swap the rear pipe out for a non silenced section |
BLACK LAB Member Since: 07 Dec 2016 Location: AYRSHIRE Posts: 165 ![]() ![]() ![]() |
That sounds pretty good . 2006 DEFENDER 90 TD5 CSW XS
2018 RANGE ROVER SPORT HSE DYNAMIC |
5 pot do you mean the manifold down pipe? As in the cat you left on or the middle section? 2008 110 2.4 XS Utility (Hagrid)
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
How does this affect the new MOT rules. I have removed my mid and rear and need to replace with something, just not sure what at the moment.
My front pipe is standard yes. But it doesnt have a silencer in it? Because its 1999 it doesnt have a CAT so is just straight down from the manifold. Instagram - @Land_Rover_Defender |
