Home > My Defender > 130 tipper project... |
stanstorey Member Since: 06 Mar 2012 Location: East Devon Posts: 123 |
Refitted the treated and painted tank cradle - just caught it before it rotted beyond repair. Having priced up a new one and a matching tank strap I am rather relieved!
Click image to enlarge Obligatory trial fit of larger wheels 285 75 16 on reverse centred disco steels Click image to enlarge |
13th May 2018 6:51am |
New rear light brackets in the making from an upcycled old Aga heat tray thingy - grease removed...
Click image to enlarge Click image to enlarge already has a strengthening fold at each end and if you cut it in half it will make two brackets... more pictures to follow - hopefully some more interesting updates! |
13th May 2018 6:57am |
That's exactly how my 110 would have looked - always wondered what it looked like when it was new!
13th May 2018 7:10am |
Like the look of your 110, saw something similar in either Plymouth or Buckfast last summer .
I have never been a great fan of wire wheels on angle grinders after one exploded on me and I had to spend sometime in A&E having bits of wire removed from a delicate area , they had embedded themselves quite deep after traveling through a pair of overalls and trousers. I now use 3M surface prep disc's. Don't make old people mad. We don't like being old in the first place, so it doesn't take much to us off. Richard |
13th May 2018 7:20am |
The perils of metalworking!
I do not even pick one up switched off without a proper set of goggles on...they are evil but effective things! |
13th May 2018 7:37am |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10751 |
Great work you have done so far, loving every moment of this thread 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
14th May 2018 8:32pm |
Few quick update pics...
Had to cut off the shock mounts as they were completely seized to the top shock bush. So new mounts and bolt kit for each side:- Click image to enlarge Light mounts (now sprayed, but were drying):- Going to run 3 x NAS lights and locate the reflector separately. Click image to enlarge Click image to enlarge Plenty of moments sorting out rear axle! Bruised thread on a stub axle - nut was particularly stubborn coming off, so thread needed cleaning up Click image to enlarge Voila Click image to enlarge Both Drive flanges were b*&gered Half shafts both good, so i guess they replaced them and not the flanges...and used any old bolts they had! Click image to enlarge Click image to enlarge The other sides stud had obviously snapped off inside the hub assembly, so someone had welded a bit studding onto the hub... which then sheared off Click image to enlarge Click image to enlarge Hub:- Click image to enlarge Drilled with a 6mm bit...then some easy out thing and it came out with ease - a rare thing! Click image to enlarge Click image to enlarge Put it back together.....bearings a bit worn, so off it comes again Click image to enlarge Click image to enlarge New discs, pads fitted and just awaiting new drive flanges and bolts to arrive. Click image to enlarge I think they warranted changing...pads were nearly new - i don't get the logic! Click image to enlarge Click image to enlarge Oh and this is always an easy and satisfying job Click image to enlarge And finally - I treated myself to a brake pipe kit - been meaning to learn to make my own for ages and this 130 needs a new front to back pipe for the MOT Click image to enlarge Last edited by stanstorey on 18th May 2018 8:27pm. Edited 2 times in total |
18th May 2018 8:13pm |
keep up good work
18th May 2018 8:20pm |
Thanks - I am strangely enjoying this one, maybe it's not having the pressure of getting it back on the road ASAP!
It is of course costing more than i pretended it would to start with |
18th May 2018 8:36pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
I had a tipper and put the air helper springs in it was a great idea. Pump them up when you have a heavy load and not a back breaking teeth chatterer when empty.
18th May 2018 10:07pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
I've drooled over that on eBay for many weeks. Mrs G is probably sick of me showing it her. I LOVE that thing |
19th May 2018 5:14am |
It's still for sale! Also take a fair chunk off price if that helps
19th May 2018 7:28am |
Few bits done this week...
Stripped dented front wing off and broken it down ready for new side and front panel- Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge 6mm 70mm wide bit of flat welded about 650mm along the bottom of the chassis rail for a bit of added strength as this section had a few small holes and was a bit thin in places. Will tidy up any welds when access is easier on the ramp! Click image to enlarge Click image to enlarge Rear lights fitted:- Will put reflectors on cross member or tipper frame above. Click image to enlarge An unexpected cost, but very necessary! Need to make up a guard as that is missing. Click image to enlarge Tank in with salvaged tank strap and some stainless bolts, ARB refitted and chassis stone chipped with that Gravelex stuff Click image to enlarge Click image to enlarge Click image to enlarge Rear end back together with lights, tow bar assembly etc. Just some rewiring to do due to awful bodged light connectors with silicone and tape! Click image to enlarge Click image to enlarge Double washered the light mounts so it leaves a gap for hosing out any mud,rather than creating a rust trap...in theory! Yes, I will cut the tekscrews down to tidy it up Click image to enlarge |
26th May 2018 5:16pm |
Practising spraying on the tipper frame and tow bar etc before i try some panels!
Click image to enlarge Winch bumper was going to be repaired....but s*d that! It's going for scrap. Never had to beat off a bumper with a lump hammer and pry bar before... Click image to enlarge Click image to enlarge On the list and parts ready! Click image to enlarge |
26th May 2018 5:24pm |
