Home > Maintenance & Modifications > Beware "heavy duty" jump leads
Page 2 of 2 <12
Dave-H
Clive wrote:
Having said that, and especially with lightweight cables, there's a lot to be said for connecting the cables between the cars with the engine running on the "donor" car and leaving it for maybe 5 - 10 minutes to give the flattened battery a chance to accumulate a bit of charge, it helps to take the strain off the cables when the heavy current starts to flow.
That is the correct way to jump start a vehicle from another ........ too many people think you simply connect the leads and crank away Rolling Eyes Guns and Landrovers .... anything else is irrelevant.
Post #690887 4th Mar 2018 6:00pm
okami
United Kingdom 1993 Defender 110 200 Tdi SW Montpellier Red
Ally home wires were banned in the US in '73/74.
Post #690931 4th Mar 2018 8:18pm
zsd-puma
Well it depends how flat the battery is on the failed vehicle. If it's turning over but sluggish then you can normally just connect and crank away. If it's totally flat it'll need the rescue vehicle to charge it for a bit.
Post #691036 5th Mar 2018 12:41am
pannawonica
Australia
Welding cable make good jumper leads, set of good crocodile clips of evil bay or mobile centre and your on your way! Thumbs Up
Post #691063 5th Mar 2018 8:04am
Greg L
Scotland 2000 Defender 90 Td5 SW Epsom Green
I second the trade card and Halfords leads they are really 35mm2
Post #695090 20th Mar 2018 11:55pm
Page 2 of 2 <12
