Home > Maintenance & Modifications > Beware "heavy duty" jump leads
Cupboard
My primary starting battery has come to the end of its useful life starting my Defender after 7 years, which I don't think is unreasonable. It's now going in to retirement powering a gas banger.
As a result of this, after work on Monday, my Defender wouldn't start. The battery was at the stage where it would still spin the engine over but the fuel and temperature needles were doing a merry dance and the engine wasn't firing. The night before I'd left the battery on charge, and it had started in the morning. I linked the auxiliary battery (which should be plenty to start the Defender by itself) and the starter turned over noticeably quicker, but it still didn't fire and the needles carried on dancing.
I then borrowed a colleague and his Ford Mondeo (it was the biggest car available!) which has a 70ah AGM battery in it. Connected my "heavy duty" jumper leads to the running Mondeo, got in the car, turned the key and it still wouldn't go. It was now turning over very quickly but the needles were still doing their merry routine. Even after leaving it connected up for ten minutes or so, it still wouldn't go.
So I called the breakdown service, fifteen minutes later a man turns up, gets in and the Defender starts on the second try with him not doing anything other than turning the key. Embarassed
Anyway, I got home and fitted the new battery that I had, and whilst I was at it I had a look at the cables linked to my aux battery. When I was fitting the battery I'd forgotten to buy cables for it so used a spare set of jump leads that I had lying around, same as the set I keep for emergencies. The total cable run is less than 30cm. I now have some 16mm2 cabling for a different project, and the 16mm2 cable has much more copper than the jump lead cable. The jump leads have more rubber so they're thicker, but in terms of useful electricity capacity they're not so good.
With just the new battery fitted my Defender is back to starting as it always used to. It doesn't turn over any quicker but the needles don't flap and it starts very quickly. I've also changed all the wiring to the second battery to use the 16mm2 cable I had, and in due course will upgrade that some more.
My guess is that on a compression stroke the voltage drop along the cables and from the battery was enough to confuse the ECU, but because there was more capacity available on the non compression strokes it sounded like it was turning quicker. So anyway. Beware Silverline's heavy duty 600A rated cables suitable for use with large vehicles. They're not. I don't know how the 600A rating of the jump leads can be justified, 16mm2 is rated at 110A and the leads are less than that.
http://www.silverlinetools.com/en-GB/Produ...ncy/456956
Post #690590 3rd Mar 2018 5:34pm
Clive
600 Amp fusing rating more like Laughing
Excessive optimism seems a common problem with a lot of stuff these days, so many things are made to "just do" the job while phrases like "heavy duty" are unjustifiably banded about to boost a buyers confidence and get them to part with some extra hard earned.
Whenever I've looked at jumper cables, I always make a point of pulling back the insulating sleeve at the clip ends to try to gauge the size of the cable, also the weight of them is a bit of a giveaway. Personally, I wouldn't bother with anything less than 35mm cable.
Having said that, and especially with lightweight cables, there's a lot to be said for connecting the cables between the cars with the engine running on the "donor" car and leaving it for maybe 5 - 10 minutes to give the flattened battery a chance to accumulate a bit of charge, it helps to take the strain off the cables when the heavy current starts to flow.
Post #690629 3rd Mar 2018 7:14pm
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
"Heavy duty jump leads" are a bit like "mud and snow tyres", meaningless marketing bullsh! Copper is what counts!
35mm2 is what you want for jump leads and winch cable. Maypole make some decent leads. The ones I have in the garage are these:
https://www.partsinmotion.co.uk/electrical...355-detail
Having spent many hours over the years starting flat Td5s when I used to sell vehicles, they can be particularly obstinate with a totally flat battery and I eventually just always used to give them 5 minutes connected to a running vehicle before trying to start them. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #690676 3rd Mar 2018 9:20pm
Cupboard
I think they'd probably have been fine if it was a problem along the lines of I'd left my lights on and I'd have done as you say. The battery was basically fully charged, just not working properly.
Post #690678 3rd Mar 2018 9:21pm
zsd-puma
It depends, 'cheap' heavy duty ones, usually just have thicker insulation to make them look good.
If you buy decent heavy duty ones they have more copper in them, but they're usually expensive as copper is expensive.
Cheap ones usually have really rubbish clamps too - some are just plastic with metal bits in the end. Cheap ones also have that insulation that goes hard in the cold, decent ones stay flexible.
Mud and Snow tyres are just the old 'Town and Country' tyres, which are usually 70/30 road biased. They just have a more blocky tread than normal pure road tyres, but don't have the softer rubber of full winter tyres. Better for things like camper vans where the tread is likely to get clogged. They're not as good off road as full all terrain tyres (which are usually 50/50), but they're normally slightly better on the road. My M+S Grabber TR's have done me well the past few days, even dragged a car with summer tyres up a hill without even a blink from the TC light.
Post #690732 3rd Mar 2018 11:35pm
ChrisCM
United Kingdom 2010 Defender 110 Puma 2.4 SW Santorini Black
A lot of cheap jump cables are constructed from CCA (copper coated aluminium) which, of course, looks nice and beefy but does not have the current carrying capacity of pure copper, beware!
The same warning is good for automotive wiring cable in general, another problem with CCA is getting a good solder connection. Thumbs Up 2010 Defender 110 Station Wagon, Santorini Black.
Post #690787 4th Mar 2018 9:24am
Screbble
Have a look at the 35mm2 jump leads at Mobile Centre and you won't go far wrong - particularly their 'kits' for the Anderson set up.
There's also a link to a magazine article/feature which pretty much sums up what others have said Thumbs Up
Post #690790 4th Mar 2018 9:35am
ChrisCM
Hi Screbble - I second that. I have a set of the Mobile Centre ones with Anderson Connector, great bit of kit! 2010 Defender 110 Station Wagon, Santorini Black.
Post #690792 4th Mar 2018 9:45am
Screbble
Can't seem to find the article now but I shall keep looking Thumbs Up
https://www.mobilecentre.co.uk/search?search=Jump+leads
Post #690794 4th Mar 2018 9:53am
leeds
Aluminium v copper?
Conductivity of aluminium is about 2/3 of copper, about 1/3 of the weight of copper and about 1/3 of the price of copper.
Now looking at that last statement you can see why aluminium is used in cheap jump leads.
IIRC American houses use aluminium conductors and high voltage power lines are aluminium. OK slightly larger transmission losses with aluminium but weight is extremely important in high voltage lines. Use copper would need pylons either closer together or different cable supporting system.
Current carrying capacity depends on cross sectional area (CSA) of conductor. 35mm2 CSA for jump leads is a good size to use in 4x4 area. A solid 35mm2 copper rod will have the same current carrying capacity as standard 35mm2 jump leads but major problem is flexibility.
For flexibility of leads with same current capacity you would need a cable with larger number of copper strands but of small strand diameter. So there are differences in useability of jump leads of same CSA. Yes the more flexible cable does cost more!
Crocodile clips are all the same? Again no, they may look the same on first looking, i.e. 180 clips look the same as clips rated at 300 amp clips. The 300 amp clips have a braided strap between the two arms of the crocodile clips. I do not quite understand the physics of the use of a braided strap between the two arms of the crocodile clips unless they are using thicker metal in the clips.
So look carefully at the specification of the jump leads.
Brendan
Post #690825 4th Mar 2018 11:48am
ARC99
Brendan...............I asked about the braided strap and was told that it allows current to pass through both halves of the clip and prevents arcing on the pin that forms the hinge between both halves of the clip. Hope that makes sense. Don't make old people mad.
Richard
Post #690829 4th Mar 2018 11:56am
leeds
Whilst I can see the braid spreading the load between the two arms of the clips. What I do not understand is surely the current limiting factor is contact area between clips and battery terminal?
I tend to wiggle the clips when fitting them to try and get better cleaner contact area between terminals and clips.
Brendan
Post #690836 4th Mar 2018 12:46pm
ChrisCM
Yes, if you consider the contact area of the SB175 Anderson connector (rated for 300A max) the contact area between even the biggest clips is minimal considering how difficult it is to get the large clips on some battery terminals. It would be interesting to know what the current carrying capacity of these clips is?
But I suppose its a bit academic really as the quality ones seem to work fine. Very Happy
As an aside I recently purchased one of the small lithium emergency jump start packs, the cable and clips on that are far smaller than my mobile centre jump leads but it still managed to start my sons 300tdi which had a flat battery. Electricary or Magic? 2010 Defender 110 Station Wagon, Santorini Black.
Post #690874 4th Mar 2018 4:09pm
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
Brendan
Aluminum was used in houses for about 10-15 years in the 70s/80s in Canada until it was determined that they cracked at the terminations and oxidized as well when they were terminated with other metals causing high resistance and fire hazards. Not sure about the US, but it hasnt been allowed or common for a few decades in Canada. They do still sell special oxidizing preventing paste at most homestores when doing renovations with older aluminum wired houses for when you have to combine aluminum with copper on new runs...
Alumium wiring...another good home idea that wasnt thought through, just like formaldehyde insulation or asbestos in your gypsum....
Post #690876 4th Mar 2018 4:18pm
kmac
These halfords leads are 35mm^2 - not a bad price especially with the trade card.
http://www.halfords.com/workshop-tools/gar...jump-leads
Post #690881 4th Mar 2018 4:49pm
