Home > Puma (Tdci) > how to remove radio
Marius
South Africa 2011 Defender 110 Puma 2.4 SW Keswick Green
how to remove radio
How do I remove the puma radio. I just HAVE to install something else
Post #63132 10th Mar 2011 4:49pm
dgardel
Italy
you need this tools
look on ebay for few pounds Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #63135 10th Mar 2011 5:07pm
tmcwhirter
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
You can make the above out of a coat hanger
Post #63138 10th Mar 2011 5:15pm
Lorryman100
or use 4 pop rivets.
Post #63156 10th Mar 2011 6:09pm
Marius
Is it basically just 4 pointy bits?
Post #63176 10th Mar 2011 6:56pm
dgardel
Italy
yes but the radio is a bit hard to extract with only the pop rivets because you not able to do a "pull-force"
Mine radio site had two small iron plates on the both side that made friction on the radio set.
The Blaupunkt tool have hooks at the end that permit to pull the radio after to have them inserted..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #63196 10th Mar 2011 8:14pm
JSG
Halfords sell them Thumbs Up John
2011 Tdci 110 CSW XS
Post #63198 10th Mar 2011 8:18pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i used 2 bent bits of wire coathanger and swore a lot Whistle
mind you it tested my finger strength trying to pull it out. BM52
Post #63202 10th Mar 2011 8:36pm
alantd
I wrestled for several days with the halfords tool. I thought I must be doing something wrong - tried every angle, every combination.
Eventually I just took the dash off - turned out one of the locating pins was bent so the extracting tool was passing down the outside of it. Quick prod with a screwdriver and all is well.
If you don't have the tools, just remove the centre section of dash and the radio is easy to extract. One that started out as a 2.4 TDCi 110 XS
Post #63227 10th Mar 2011 10:54pm
AndrewS
Thumbs Up Thumbs Up This is the easy way and you can then route the cables easier when you push/force it all back into place Thumbs Up 130's have feeling's as well you know Smile
Post #63238 11th Mar 2011 6:55am
Two bits of bent wire with the ends filed to provide the extraction catches. Takes about five minutes to make, provided that you already have the radio out in order to see what you need to file!
Post #63253 11th Mar 2011 9:15am
TC
When you do this make sure the retaining springs are bent back into shape (if miss shapen through extraction), otherwise you will find the weight of the stereo will force it to kick out at either the top or bottom.
Post #63275 11th Mar 2011 12:00pm
