Home > Puma (Tdci) > how to remove radio |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
How do I remove the puma radio. I just HAVE to install something else
10th Mar 2011 4:49pm |
you need this tools
look on ebay for few pounds Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
10th Mar 2011 5:07pm |
tmcwhirter Member Since: 02 Dec 2010 Location: UK Posts: 23 |
You can make the above out of a coat hanger
10th Mar 2011 5:15pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
or use 4 pop rivets.
10th Mar 2011 6:09pm |
Is it basically just 4 pointy bits?
10th Mar 2011 6:56pm |
yes but the radio is a bit hard to extract with only the pop rivets because you not able to do a "pull-force"
Mine radio site had two small iron plates on the both side that made friction on the radio set. The Blaupunkt tool have hooks at the end that permit to pull the radio after to have them inserted..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
10th Mar 2011 8:14pm |
JSG Member Since: 12 Jul 2007 Location: Berkshire Posts: 2412 |
Halfords sell them John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
10th Mar 2011 8:18pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
i used 2 bent bits of wire coathanger and swore a lot
mind you it tested my finger strength trying to pull it out. BM52 |
10th Mar 2011 8:36pm |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 |
I wrestled for several days with the halfords tool. I thought I must be doing something wrong - tried every angle, every combination.
Eventually I just took the dash off - turned out one of the locating pins was bent so the extracting tool was passing down the outside of it. Quick prod with a screwdriver and all is well. If you don't have the tools, just remove the centre section of dash and the radio is easy to extract. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
10th Mar 2011 10:54pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17569 |
Two bits of bent wire with the ends filed to provide the extraction catches. Takes about five minutes to make, provided that you already have the radio out in order to see what you need to file!
11th Mar 2011 9:15am |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 |
When you do this make sure the retaining springs are bent back into shape (if miss shapen through extraction), otherwise you will find the weight of the stereo will force it to kick out at either the top or bottom. |
11th Mar 2011 12:00pm |
