![]() | Home > Puma (Tdci) > how to remove radio |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 ![]() ![]() ![]() |
How do I remove the puma radio. I just HAVE to install something else
you need this tools
![]() look on ebay for few pounds Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
tmcwhirter Member Since: 02 Dec 2010 Location: UK Posts: 23 ![]() ![]() ![]() |
You can make the above out of a coat hanger
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
or use 4 pop rivets.
Is it basically just 4 pointy bits?
yes but the radio is a bit hard to extract with only the pop rivets because you not able to do a "pull-force"
Mine radio site had two small iron plates on the both side that made friction on the radio set. The Blaupunkt tool have hooks at the end that permit to pull the radio after to have them inserted..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Halfords sell them
![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
i used 2 bent bits of wire coathanger and swore a lot
![]() mind you it tested my finger strength trying to pull it out. BM52 |
alantd Member Since: 14 Dec 2008 Location: Northamptonshire Posts: 1513 ![]() ![]() ![]() |
I wrestled for several days with the halfords tool. I thought I must be doing something wrong - tried every angle, every combination.
Eventually I just took the dash off - turned out one of the locating pins was bent so the extracting tool was passing down the outside of it. Quick prod with a screwdriver and all is well. If you don't have the tools, just remove the centre section of dash and the radio is easy to extract. One that started out as a 2.4 TDCi 110 XS + New Defender 110 First Edition |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17569 ![]() ![]() ![]() |
Two bits of bent wire with the ends filed to provide the extraction catches. Takes about five minutes to make, provided that you already have the radio out in order to see what you need to file!
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
When you do this make sure the retaining springs are bent back into shape (if miss shapen through extraction), otherwise you will find the weight of the stereo will force it to kick out at either the top or bottom. |
