Home > Off Topic > Any joiners? timber size for stud wall
Mean Green
I need to build a stud wall for an ensuite. I am happy with the build and how to put it all together, but I am confused (confused myself) about the timber size.
I ideally want to make the wall about 100mm thick to the finished plaster faces and I planned to use CLS. There will be a door in the wall - as far as I can see standard door frames are 115mm (which i could live with), so assuming I use 12.5mm plasterboard on both sides and allow 6mm for plaster skim (3mm each side) that leaves 84mm for framing. CLS comes in 63x38 and 89x38mm widths. Therefore 1 is too wide and the other is too narrow - assuming the edge of the door frame wants to be flush with the finish plaster (and then the facing on top).
So how do I do it - or am i missing something?
Post #664808 16th Nov 2017 3:39pm
ibexman
For 3x2 use 4 and a quarter lining and 4x2 5and a quarter lining or convert that to mm old school me Thumbs Up
Post #664810 16th Nov 2017 3:43pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
I am not a joiner but I used to have a laugh that at B&Q you used to be able to buy 2 meters of 4" x 2".............
Sorry I know this is of no help at all...... Cheers Don.
Post #664813 16th Nov 2017 3:58pm
ibexman
Gif using CLS cut linings to suit
Post #664817 16th Nov 2017 4:03pm
Mean Green
Ah! Perfect!
Knew there must be an easy answer! 108mm door frame.
Post #664818 16th Nov 2017 4:04pm
What puddle?
...or
2 x 9.5 mm plasterboard = 19mm
CLS = 89mm
plaster skim @3.5mm = 7mm (plasterers love it when you tell them to apply 3.5mm!)
= 115mm Now left.
Post #664839 16th Nov 2017 5:34pm
BarryT
Wales 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
4"x2" (100mmx50mm) or 3"x2" (75mmx5omm) both are perfectly adequate for a stud partition, don't forget the insulation.
Post #664854 16th Nov 2017 6:29pm
defender9
United Kingdom 2015 Defender 90 Puma 2.2 SW Keswick Green
I have just finished a stud wall in the bedroom, used 4x2 strengthened with ply on one side then 12mm plasterboard both sides.
Post #664895 16th Nov 2017 8:14pm
Martin 01
As above + 100mm Rockwell insulation.
And yes I’m a chippie Thumbs Up
Post #664941 16th Nov 2017 9:35pm
