Home > Off Topic > Any joiners? timber size for stud wall |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
For 3x2 use 4 and a quarter lining and 4x2 5and a quarter lining or convert that to mm old school me
16th Nov 2017 3:43pm |
DonH2000 Member Since: 12 Jan 2015 Location: North Kent Posts: 551 |
I am not a joiner but I used to have a laugh that at B&Q you used to be able to buy 2 meters of 4" x 2".............
Sorry I know this is of no help at all...... Cheers Don. |
16th Nov 2017 3:58pm |
Gif using CLS cut linings to suit
16th Nov 2017 4:03pm |
Mean Green Member Since: 15 Sep 2011 Location: South Ayrshire Posts: 280 |
Ah! Perfect!
Knew there must be an easy answer! 108mm door frame. Cheers |
16th Nov 2017 4:04pm |
What puddle? Member Since: 25 Oct 2013 Location: Reading Posts: 952 |
...or
2 x 9.5 mm plasterboard = 19mm CLS = 89mm plaster skim @3.5mm = 7mm (plasterers love it when you tell them to apply 3.5mm!) = 115mm Now left. |
16th Nov 2017 5:34pm |
BarryT Member Since: 17 Feb 2015 Location: not far from RED WHARF BAY Posts: 117 |
4"x2" (100mmx50mm) or 3"x2" (75mmx5omm) both are perfectly adequate for a stud partition, don't forget the insulation.
16th Nov 2017 6:29pm |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 |
I have just finished a stud wall in the bedroom, used 4x2 strengthened with ply on one side then 12mm plasterboard both sides.
16th Nov 2017 8:14pm |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 |
As above + 100mm Rockwell insulation. And yes I’m a chippie |
16th Nov 2017 9:35pm |
